[postgis-users] Expand odd shapes
Rémi Cura remi.cura at gmail.com
Tue Jun 9 23:43:00 PDT 2015
Why not use ST_DWithin with the original triangle, it is the best option
regarding speed and precision.
Cheers
Remi-C
Le 10 juin 2015 01:30, "Andy Colson" <andy at squeakycode.net> a écrit :
> At first I thought no, because it creates a circle around a point:
> "Returns a geometry that represents all points whose distance from this
> Geometry is less than or equal to distance"
> But now that I read it again, maybe it does do what I'd like.  If I pass a
> rectangle, it'll return all points <= radius.
> I'll give it a shot and try it out.  Thanks for the help.
> -Andy
> On 06/09/2015 04:48 PM, Basques, Bob (CI-StPaul) wrote:
>> Can you use ST_Buffer??
>> bobb
>>  On Jun 9, 2015, at 4:34 PM, Andy Colson <andy at squeakycode.net> wrote:
>>> Hi all.
>>> I have buffer selection problem.  My site can drop a point, then find
>>> all the parcels within 100 feet of that point.  No problem.
>>> One client however would like to select a parcel (maybe its a square,
>>> maybe its a triangle, or any other odd shape), and find all other parcels
>>> within 100 feet of any point within the source parcel.
>>> 100 is optional.  They could choose 50, or 150.
>>> I'm not sure how to do something like this.  I found ST_Expand, but
>>> that'll create a bounding box around the triangle.
>>> ST_TransScale could scale it, but I'm not sure what the scale is.  The
>>> user might type in 50 feet or 150 feet, I'm not sure how to calculate a
>>> deltaX and deltaY scale for that.
>>> Any hints on how I might go about this?  I'm a bit stuck.
>>> Thanks,
>>> -Andy
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150610/db908f9f/attachment.html>
