[postgis-users] Find unique date and code values before applying st_intersects
Gery .
gamejihou at hotmail.com
Thu Jun 11 13:36:30 PDT 2015
Hello,
I have two tables, one containing polygons and one with points:
# polygonsgid | integer | not null default nextval('cuadro_produce_region_gid_seq'::regclass)id | character varying(10) | zona | character varying(10) | area | character varying(10) | cod | double precision | seccion | double precision | ordxdistc | double precision | geom | geometry(PolygonZM,4326) |
# points nombre_embarcacion | character varying(150) | matricula_embarcacion | character varying(150) | tipo_casco | character varying(150) | capacidad_bodega | character varying(150) | nombre_aparejo | character varying(150) | descripcion_proveedor | character varying(150) | fecha | character varying(150) | longitud | numeric | latitud | numeric | velocidad | numeric | rumbo | numeric | ts | tsvector | geom | geometry(Point,4326) |
Finding all points, first filtered by velocity ("velocidad" field), inside each region was quite easy:
select cuadro_produce_region.gid,cuadro_produce_region.area,cuadro_produce_region.zona,cuadro_produce_region.cod,count(*) as Nro from temporada1erapesca2012_point_wgs84,cuadro_produce_region where (temporada1erapesca2012_point_wgs84.velocidad between '0.2' and '1.6') and st_intersects(cuadro_produce_region.geom,temporada1erapesca2012_point_wgs84.geom) group by cuadro_produce_region.gid order by cuadro_produce_region.gid,cuadro_produce_region.cod;
but now I need to select unique values from fields "fecha" and "matricula_embarcacion" of the table 'temporada1erapesca2012_point_wgs84' first and then apply the intersection with the 'cuadro_produce_region' table, I tried "distinct" in the where clause with no success so far:
select cuadro_produce_region.gid,cuadro_produce_region.area,cuadro_produce_region.zona,cuadro_produce_region.cod,count(*) as Nro from temporada1erapesca2012_point_wgs84,cuadro_produce_region where (temporada1erapesca2012_point_wgs84.velocidad between '0.2' and '1.6' and distinct(temporada1erapesca2012_point_wgs84.matricula_embarcacion) and distinct(temporada1erapesca2012_point_wgs84.fecha)) and st_intersects(cuadro_produce_region.geom,temporada1erapesca2012_point_wgs84.geom) group by cuadro_produce_region.gid order by cuadro_produce_region.gid,cuadro_produce_region.cod;
how could I do this query? "fecha" field has this structure: 16/06/2012 03:00
Any hints are welcomed, thanks in advance,
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150611/ba980487/attachment.html>
