[postgis-users] 2.1.6 Released
Rémi Cura remi.cura at gmail.com
Thu Mar 26 13:37:15 PDT 2015
Hum you can do a simple test,
for the table you are using,
look at the pgpoint column type number (called pcid)
You can know this like this
    SELECT pc_astext(pt)
    FROM xyz_patches, pc_explode(pa) as pt
    LIMIT 1
Know look into public.pointcloud_formats, the xml schema corresponding to
the pcid you found.
You should see if it is compressed.
Another method is to take a patch and compare it with the uncompressed
version.
SELECT block_id, pa, pc_uncompress(pa)
FROM patches
LIMIT 1
Here is the correct way to write your querry anyway, you should see a great
speed up.
--recent postgres
SELECT block_id , pc_get(pt, 'X') as x, pc_get(pt, 'Y') as y, pc_get(pt,
'Z') as z
--old postgres
WITH points AS (
SELECT block_id, pc_explode(pa) as pt
'Z') as z
FROM points
Cheers,
Rémi-C
2015-03-26 19:09 GMT+01:00 Jonathan Moules <J.Moules at hrwallingford.com>:
>  Hi Rémi,
> Thanks for the reply and information.
> I’m afraid I inherited this database and don’t know much about it (or
> pointcloud).
> Looking into though, I doubt it’s compressed, we extract the data with:
> select block_id , pc_get(pc_explode(pa), 'X') as x, pc_get(pc_explode(pa),
> 'Y') as y, pc_get(pc_explode(pa), 'Z') as z from xyz_patches
> so using pc_get rather than pc_uncompress.
> On the other hand, there are 6 entries in pointcloud_formats which all
> have the “<Metadata name="compression">dimensional</Metadata>” line set.
> But I can’t decipher the documentation well enough to know if the data
> actually uses it.
> Cheers,
> Jonathan
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Rémi Cura
> *Sent:* Thursday, March 26, 2015 5:33 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] 2.1.6 Released
> Hey,
> if you use the compression of patch and sensible xml schema,
> you should already have a 1:2 to 1:4 compression of the point size.
> (compared to binary ply in my case)
> Cheers,
> Rémi-C
> 2015-03-26 18:05 GMT+01:00 Jonathan Moules <J.Moules at hrwallingford.com>:
> Hi Paul,
> I suspect I know the answer to this (“no”), but to confirm, is the disk
> saving for points going to apply to points stored using the pointcloud
> extension in a postgis database?
> Thanks,
> Jonathan
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Paul Ramsey
> *Sent:* Friday, March 20, 2015 5:45 PM
> *Subject:* [postgis-users] 2.1.6 Released
> The 2.1.6 release of PostGIS is now available
> <http://download.osgeo.org/postgis/source/postgis-2.1.6.tar.gz>.
> The PostGIS development team is happy to release patch for PostGIS 2.1,
> the 2.1.6 release. As befits a patch release, the focus is on bugs,
> breakages, and performance issues. Users with large tables of points will
> want to priorize this patch, for substantial (~50%) disk space savings.
> *Enhancements*
> ·         #3000, Ensure edge splitting and healing algorithms use indexes
> ·         #3048, Speed up geometry simplification (J.Santana @ CartoDB)
> ·         #3050, Speep up geometry type reading (J.Santana @ CartoDB)
> *Bug Fixes*
> ·         #2941, allow geography columns with SRID other than 4326
> ·         #3069, small objects getting inappropriately fluffed up w/ boxes
> ·         #3068, Have postgis_typmod_dims return NULL for unconstrained
> dims
> ·         #3061, Allow duplicate points in JSON, GML, GML ST_GeomFrom*
> functions
> ·         #3058, Fix ND-GiST picksplit method to split on the best plane
> ·         #3052, Make operators <-> and <#> available for PostgreSQL < 9.1
> ·         #3045, Fix dimensionality confusion in &&& operator
> ·         #3016, Allow unregistering layers of corrupted topologies
> ·         #3015, Avoid exceptions from TopologySummary
> ·         #3020, ST_AddBand out-db bug where height using width value
> ·         #3031, Allow restore of Geometry(Point) tables dumped with
> empties in them
> View all closed tickets
> <http://trac.osgeo.org/postgis/query?status=closed&groupdesc=1&group=priority&milestone=PostGIS+2.1.6&order=priority>
> Paul Ramsey
> http://cleverelephant.ca
> http://postgis.net
> This message has been scanned for viruses by MailControl
> <http://www.mailcontrol.com/>, a service from BlackSpider Technology
> Click here <https://www.mailcontrol.com/sr/MZbqvYs5QwJvpeaetUwhCQ==> to
> report this email as spam.
> *HR Wallingford and its subsidiaries* uses faxes and emails for
> confidential and legally privileged business communications. They do not of
> themselves create legal commitments. Disclosure to parties other than
> addressees requires our specific consent. We are not liable for
> unauthorised disclosures nor reliance upon them.
> If you have received this message in error please advise us immediately
> and destroy all copies of it.
> HR Wallingford Limited
> Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
> Registered in England No. 02562099
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150326/d6bc5fb5/attachment.html>
