[postgis-users] 2.1.6 Released
Jonathan Moules J.Moules at hrwallingford.com
Fri Mar 27 04:48:13 PDT 2015
Thanks Rémi. They do indeed appear to be compressed using your two tests.
And the improved SQL is about 20% faster.
Thanks!
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Rémi Cura
Sent: Thursday, March 26, 2015 8:37 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] 2.1.6 Released
Hum you can do a simple test,
for the table you are using,
look at the pgpoint column type number (called pcid)
You can know this like this
    SELECT pc_astext(pt)
    FROM xyz_patches, pc_explode(pa) as pt
    LIMIT 1
Know look into public.pointcloud_formats, the xml schema corresponding to the pcid you found.
You should see if it is compressed.
Another method is to take a patch and compare it with the uncompressed version.
SELECT block_id, pa, pc_uncompress(pa)
FROM patches
LIMIT 1
Here is the correct way to write your querry anyway, you should see a great speed up.
--recent postgres
SELECT block_id , pc_get(pt, 'X') as x, pc_get(pt, 'Y') as y, pc_get(pt, 'Z') as z
--old postgres
WITH points AS (
SELECT block_id, pc_explode(pa) as pt
FROM points
Cheers,
Rémi-C
2015-03-26 19:09 GMT+01:00 Jonathan Moules <J.Moules at hrwallingford.com<mailto:J.Moules at hrwallingford.com>>:
Hi Rémi,
Thanks for the reply and information.
I’m afraid I inherited this database and don’t know much about it (or pointcloud).
Looking into though, I doubt it’s compressed, we extract the data with:
select block_id , pc_get(pc_explode(pa), 'X') as x, pc_get(pc_explode(pa), 'Y') as y, pc_get(pc_explode(pa), 'Z') as z from xyz_patches
so using pc_get rather than pc_uncompress.
On the other hand, there are 6 entries in pointcloud_formats which all have the “<Metadata name="compression">dimensional</Metadata>” line set. But I can’t decipher the documentation well enough to know if the data actually uses it.
Cheers,
Jonathan
From: postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org> [mailto:postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org>] On Behalf Of Rémi Cura
Sent: Thursday, March 26, 2015 5:33 PM
Hey,
if you use the compression of patch and sensible xml schema,
you should already have a 1:2 to 1:4 compression of the point size.
(compared to binary ply in my case)
Cheers,
Rémi-C
2015-03-26 18:05 GMT+01:00 Jonathan Moules <J.Moules at hrwallingford.com<mailto:J.Moules at hrwallingford.com>>:
Hi Paul,
I suspect I know the answer to this (“no”), but to confirm, is the disk saving for points going to apply to points stored using the pointcloud extension in a postgis database?
Thanks,
Jonathan
From: postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org> [mailto:postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org>] On Behalf Of Paul Ramsey
Sent: Friday, March 20, 2015 5:45 PM
Subject: [postgis-users] 2.1.6 Released
The 2.1.6 release of PostGIS is now available<http://download.osgeo.org/postgis/source/postgis-2.1.6.tar.gz>.
The PostGIS development team is happy to release patch for PostGIS 2.1, the 2.1.6 release. As befits a patch release, the focus is on bugs, breakages, and performance issues. Users with large tables of points will want to priorize this patch, for substantial (~50%) disk space savings.
Enhancements
•         #3000, Ensure edge splitting and healing algorithms use indexes
•         #3048, Speed up geometry simplification (J.Santana @ CartoDB)
•         #3050, Speep up geometry type reading (J.Santana @ CartoDB)
Bug Fixes
•         #2941, allow geography columns with SRID other than 4326
•         #3069, small objects getting inappropriately fluffed up w/ boxes
•         #3068, Have postgis_typmod_dims return NULL for unconstrained dims
•         #3061, Allow duplicate points in JSON, GML, GML ST_GeomFrom* functions
•         #3058, Fix ND-GiST picksplit method to split on the best plane
•         #3052, Make operators <-> and <#> available for PostgreSQL < 9.1
•         #3045, Fix dimensionality confusion in &&& operator
•         #3016, Allow unregistering layers of corrupted topologies
•         #3015, Avoid exceptions from TopologySummary
•         #3020, ST_AddBand out-db bug where height using width value
•         #3031, Allow restore of Geometry(Point) tables dumped with empties in them
View all closed tickets<http://trac.osgeo.org/postgis/query?status=closed&groupdesc=1&group=priority&milestone=PostGIS+2.1.6&order=priority>.
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
This message has been scanned for viruses by MailControl<http://www.mailcontrol.com/>, a service from BlackSpider Technology
Click here<https://www.mailcontrol.com/sr/MZbqvYs5QwJvpeaetUwhCQ==> to report this email as spam.
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150327/81918e08/attachment.html>
