[postgis-users] postgis_restore.pl
Paul Ramsey
pramsey at cleverelephant.ca
Thu May 28 12:22:19 PDT 2015
For 2.0->2.1 restore you should be able to use pg_restore directly on
the dump file, no need to filter it through the postgis_restore.pl
file...
P
On Thu, May 28, 2015 at 8:58 AM, Paul & Caroline Lewis
<paulcaz80 at hotmail.com> wrote:
> Hi,
> I'm trying to restore after a Hard upgrade from Postgresql 9.0 and PostGIS
> 2.0SVN to Postgresql 9.3 with Postgis 2.1 and PointCloud.
> The back-up dump went fine and the re-installation of 9.3, 2.1 and
> Pointcloud all fine.
> This is a LiDAR DB and the back-up dump file is 513GB, so its a large
> restore job (I'd imagine).
> Anyway, I've set the following process off:
> sudo perl /usr/share/postgresql/9.3/contrib/postgis-2.1/postgis_restore.pl
> "/storage2/bkup/pg_upgrade.backup" | psql -h localhost -p 5432 -U postgres
> lidar_db 2> errors.txt
> The process gets to:
> Writing manifest of things to read from dump file...
> Writing ASCII to stdout...
> and would seem to be stuck as it has been in this state for over 24 hours.
> Using 'top' I can't see any CPU or MEM values to suggest the process is
> still working, just very busy because of the large file.
> The process creates a new 630kb file called:
> pg_upgrade.backup.lst
> but it is not getting any bigger.
> Basically, should a 500GB+ dump file take hours to restore and should it be
> stuck in this state for so long??
> Where could I look for the problem and what solutions might I try.
> The erros.txt file gets created but its empty 0kb.
> Regards,
> Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
