[postgis-users] Running PostGIS from Eclipse
Sylvain Racine
sracine at igreffe.net
Fri Nov 6 16:24:54 PST 2015
Hi Ruby,
I programmed this afternoon a postGIS query test in C++ with Eclipse. I encountered some issues with the compiler and the linker in order to add libpq library to my project. If it is yours, please refers to this page:
http://www.postgresql.org/docs/9.1/static/libpq-build.html
I had to add three flags to Eclipse Mars 1 release 4.5.1 to get a perfect compilation. One is located in Project/Properties/C/C++ Build/Settings/GCC C++ Compiler/Miscellaneous/Other flags. I added '-c -I/usr/include/postgresql ' where /usr/include/postgresql is path returned by typing in a shell pg_config --includedir. The other one is located in Project/Properties/C/C++ Build/Settings/GCC C++ Linker/Libraries/Library search path. I added '/usr/lib/x86_64-linux-gnu' where this path is returned by typing in a shell pg_config --libdir. The last one is located in Project/Properties/C/C++ Build/Settings/GCC C++ Linker/Miscellaneous/Other object . I added '-lpq'.
After that, I programmed a parametric query with both non-spatial and spatial fields. Notice that with libpq library, there are two modes to return result: binary and text modes. I chose text mode. Everything worked fine without any error message.
I don't know which language that you program in Eclipse.
Hope that this hint will help you
Regards
Sylvain Racine
----------------original message-----------------
De: "Ruby Tahboub" ruby.tahboub at gmail.com
A: "PostGIS Users Discussion"
Date: Thu, 5 Nov 2015 17:33:02 -0500
> I can run Postgres/ PostGIS from command line. No, I'm not using plugins, I
> use eclipse to debug the backend code, it works for Postgresql queries but
> it gives error for anything spatial. I suspect it's an eclipse
> configuration.
> On Thu, Nov 5, 2015 at 4:41 PM, Sylvain Racine sracine at igreffe.net wrote:
>> Hi Ruby,
>> Do you talk about compiling PostGIS in C++ with Eclipse or to access
>> PostgreSQL DB with a SQL plugin in Eclipse? If yes, please indicate the
>> name of your plugin.
>> Regards
>> Sylvain Racine
>> A: postgis-users at lists.osgeo.org
>> Date: Thu, 5 Nov 2015 15:15:31 -0500
>> > Dear All,
>> > I need help with configuring PostGIS to run from Eclipse. I already have
>> > Postgres/PostGIS installed, and I can run Postgres from Eclipse.
>> > When I type a query with a spatial predicate, I get the following error
>> > from parser:
>> > ERROR: could not access file "$libdir/postgis-2.2": No such file or
>> > directory
>> > Thanks!
>> > Ruby
>> __________________________________________________
>> > postgis-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/postgis-users
