[postgis-users] compatible postgis-java tag for postgis-2.2.0 ?
Phillip Ross
phillip.w.g.ross+postgis-users at gmail.com
Tue Nov 17 09:58:15 PST 2015
Hi Bandaru... since the split from core, the postgis jdbc extensions
are no longer versioned along with the PostGIS core. The latest
release of the the jdbc extensions works fine with postgis-2.2.0.
Hope that helps!
- Phillip
On Tue, Nov 17, 2015 at 8:15 AM, Bandaru Muralikrishna
<bandaru.muralikrishna at enterprisedb.com> wrote:
> Hi,
> I want to build postgis jdbc driver with postgis-2.2.0 sources. I
> didn't see any postgis-java related files with postgis-2.2.0 sources.
> The statement from http://postgis.net/source/ link is saying "As of
> June 2015, PostGIS JDBC development has been split from PostGIS core
> and is now on github." I can see four tags under postgis-java git hub
> repository ( https://github.com/postgis/postgis-java/ ). So which one
> is compatible tag for me to build postgis jdbc driver with
> Thanks & Regards
> Murali Krishna
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
