[postgis-users] Error with ST functions
Sandro Santilli strk at keybit.net
Thu Nov 19 09:23:02 PST 2015
On Thu, Nov 19, 2015 at 06:10:52PM +0100, Lorenzo Bottaccioli wrote:
> Postgis installed by ubuntu repository, then
> createdb mydb
> psql -d mydb -f postgis_comments.sql
> psql -d mydb -f spatial_ref_sys.sql
> psql -d mydb -f rtpostgis.sql
> psql -d mydb -f raster_comments.sql
> psql -d mydb -f topology.sql
> psql -d mydb -f topology_comments.sql
See if the sourced file did contain that function:
 grep -i st_bandisnodata rtpostgis.sql
You should see this line:
 CREATE OR REPLACE FUNCTION st_bandisnodata(rast raster, band integer DEFAULT 1, forceChecking boolean DEFAULT FALSE)
If not, it'd be a broken package.
If you find it, someone must have removed that function later.
It should be possible to get it back by:
 psql -d mydb -f rtpostgis_upgrade_21_minor.sql
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
