[postgis-users] Help with SQL query?
Roxanne Reid-Bennett rox at tara-lu.com
Mon Nov 23 16:46:19 PST 2015
On 11/23/2015 12:41 PM, Darrel Maddy wrote:
> Dear Pierre,
> I was not looking for a total solution and I am grateful for the
> suggestion.
> Although it may not look like it, I did consult the documentation and
> also I have Regina’s book beside me.  Unfortunately, for me at least,
> both documents assume some knowledge of SQL – which I do not have.  I
> am also trying to do this simultaneously with a large number of other
> things that are new to me.  I do not find the errors reported at all
> informative and consider the query I am trying to perform to be
> relatively trivial and hence I had hoped the structure of the query
> might have been more intuitive.  For others it may be.
FWIW - I don't play with rasters, but this appears to be a pure SQL
thing... add "as rast" like below and try again.
SELECT ST_MapAlgebra(deposition.rast, concentrated.rast, 'IF
concentrated > 6 THEN deposition ELSE NULL ENDIF ' )
as rast
             FROM mymodel.deposition, mymodel.concentrated
             WHERE ST_UpperleftX(mymodel.deposition.rast) =
ST_UpperleftX(mymodel.concentrated.rast) AND
                          ST_UpperleftY(mymodel.deposition.rast) =
Roxanne
> I will try not to bother you again.
> Darrel
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Pierre Racine
> *Sent:* 23 November 2015 20:30
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Help with SQL query?
> The expression has to stay as it was: 'IF [rast2] > threshold THEN
> [rast1] ELSE NULL ENDIF '
> Just replace the threshold value as you did.
> Do not try to replace the [rast2] and [rast1]. They refer to the first
> and second raster pixel values. Read the ST_Mapalgebra doc…
> Don’t expect our suggestions to work blindly. I did not test this
> query. I’m not in your context. I expect you read the doc about all
> the mentioned functions and adjust for your specific context. I said
> “your query should “look like” this”…
> Pierre
> *On Behalf Of *Darrel Maddy
> *Sent:* Monday, November 23, 2015 2:47 PM
> OK I spoke too soon.
> I tried this:
> SELECT (ST_SummaryStats(ST_Union(rast))).sum sum
> FROM (SELECT ST_MapAlgebra(deposition.rast, concentrated.rast, 'IF
> ST_UpperleftY(mymodel.deposition.rast) ) foo;
> And all I get is rast does not exist.
> I’m afraid the penny has not dropped yet L
> Darrel
> *Sent:* 23 November 2015 16:30
> <mailto:postgis-users at lists.osgeo.org>>
> Dear Pierre and Rasmus,
> Many thanks for trying to help.
> Rasmus: I am aware of GMT but I was looking for a solution in postgis
> so that I can keep all of the data extraction in one place.
> Pierre: That is exactly what I was looking for and very many thanks
> for including the explanation.  I am a little overwhelmed with the
> number of functions offered in postgis. It is certainly a remarkable
> tool.  Watching the queries plough through my datasets is a pleasure –
> albeit the results do not always please me J
> Hopefully I can put this to work later tonight.
> Best wishes
> Darrel
> *Sent:* 23 November 2015 16:17
> Darrel,
> 1)Create a new raster selecting the right pixels with
> ST_MapAlgebra(raster, raster)
> 2)Make sure only intersecting rasters are processed by using their
> upper left corner X and Y coordinates (with ST_UpperLeftX() and
> UpperLeftY())
> 3)Sum the selected pixels with ST_SummaryStats(rast)
> All in all a global query should look like this:
> FFOM (SELECT ST_MapAlgebra(tableA.rast, tableB.rast, 'IF [rast2] >
> threshold THEN [rast1] ELSE NULLENDIF ' )
> FROM tableA, tableB
>  WHERE ST_UpperleftX(tableA.rast) = ST_UpperleftX(tableB.rast) AND
>                          ST_UpperleftY(tableA.rast) =
> ST_UpperleftY(tableB.rast) AND
>                          maybe some other condition here if you get
> time series e.g. tableA.year = tableB.year AND tableA.month =
> tableB.month) foo
> If you have millions of tile you could create indexes on
> ST_UpperleftX(tableA.rast), ST_UpperleftX(tableB.rast),
> ST_UpperleftY(tableA.rast) and ST_UpperleftY(tableB.rast) to make the
> query faster.
> You could also just use WHERE ST_Intersects(tableA.rast, tableB.rast)
> instead…
> Pierre
> *Sent:* Monday, November 23, 2015 7:20 AM
> *Subject:* [postgis-users] Help with SQL query?
> Dear all,
> As you know I am relatively new to postgis and SQL and therefore  I
> have much to learn. However, I am facing a paper deadline and need to
> do some quick analysis of the data I have and I am struggling to
> figure out how best to pursue what I need to do.
> I have a significant number of rasters which have double precision
> values.  Without going into detail about what the rasters represent, I
> need to extract and sum values from one set of rasters in say table A
> based upon  values in another set of rasters in say table B  where the
> pixel value in the raster from Table B exceeds a threshold. Both
> tables are the same size (rasters are tiled) but I also need to figure
> out how I make sure the correct rasters are compared.  They have
> filenames like this rastervariable_10.tif, rastervariable_100.tif ,
> presumably I need to use a logical expression to strip the numerical
> value (in this case this represents the year) and then order on that
> basis?
> I can do this in QGIS one at a time but that is a little clumsy and
> rather time consuming.
> If someone can just point me in the right direction I am sure I can
> figure out the rest for myself.
> Apologies once more for asking what is probably a rather trivial
> question and yet again demonstrating my ignorance.
> Many thanks
> Darrel
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
[At other schools] I think the most common fault in general is to teach students how to pass exams instead of teaching them the science.
Donald Knuth
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151123/53c82e1e/attachment.html>
