[postgis-users] Help with SQL query?
Birgit Laggner birgit.laggner at ti.bund.de
Tue Nov 24 04:18:38 PST 2015
Hi Darrel,
my PostGIS version is too old for testing, but if I read the
documentation right, then your expression has to be SQL. And IF THEN
ELSE etc. is not SQL as far as I know - SQL has CASE WHEN.
So, I would assume, you would need to write your expression like this:
'CASE WHEN [rast2] > 0.0 THEN [rast1] ELSE NULL END'
I am curious if this helps with your error...
Regards,
Birgit
Am 24.11.2015 um 10:09 schrieb Darrel Maddy:
> Dear Roxanne,
> Many thanks. I did pickup that issue shortly after my last post and it
> cured the first problem.
> There is still an SQL issue with the expression however.
> I tried ‘IF [rast2]>0.0 THEN [rast1] ELSE NULL ENDIF’
> This produces an error at $2. I can remove that problem by doing this
> ‘IF ([rast2]>0.0) THEN [rast1] ELSE NULL ENDIF’
> But then I get the error at THEN
> Curiously ‘[rast2]+[rast1]’  works as intended so somehow the
> conditional is being specified incorrectly.
> Unfortunately there is nothing in the documentation which helps me
> with this variant.
> I will keep trying.
> Darrel
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Roxanne Reid-Bennett
> *Sent:* 24 November, 2015 12:46 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] Help with SQL query?
> On 11/23/2015 12:41 PM, Darrel Maddy wrote:
>     Dear Pierre,
>     I was not looking for a total solution and I am grateful for the
>     suggestion.
>     Although it may not look like it, I did consult the documentation
>     and also I have Regina’s book beside me.  Unfortunately, for me at
>     least, both documents assume some knowledge of SQL – which I do
>     not have.  I am also trying to do this simultaneously with a large
>     number of other things that are new to me.  I do not find the
>     errors reported at all informative and consider the query I am
>     trying to perform to be relatively trivial and hence I had hoped
>     the structure of the query might have been more intuitive.  For
>     others it may be.
> FWIW - I don't play with rasters, but this appears to be a pure SQL
> thing... add "as rast" like below and try again.
> SELECT ST_MapAlgebra(deposition.rast, concentrated.rast, 'IF
> concentrated > 6 THEN deposition ELSE NULL ENDIF ' )
> as rast
> FROM mymodel.deposition, mymodel.concentrated
> WHERE ST_UpperleftX(mymodel.deposition.rast) =
> ST_UpperleftX(mymodel.concentrated.rast) AND
>                          ST_UpperleftY(mymodel.deposition.rast) =
> Roxanne
>     I will try not to bother you again.
>     Darrel
>     [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of
>     *Pierre Racine
>     *Sent:* 23 November 2015 20:30
>     *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>     <mailto:postgis-users at lists.osgeo.org>
>     The expression has to stay as it was: 'IF [rast2] > threshold THEN
>     [rast1] ELSE NULL ENDIF '
>     Just replace the threshold value as you did.
>     Do not try to replace the [rast2] and [rast1]. They refer to the
>     first and second raster pixel values. Read the ST_Mapalgebra doc…
>     Don’t expect our suggestions to work blindly. I did not test this
>     query. I’m not in your context. I expect you read the doc about
>     all the mentioned functions and adjust for your specific context.
>     I said “your query should “look like” this”…
>     Pierre
>     *Darrel Maddy
>     *Sent:* Monday, November 23, 2015 2:47 PM
>     OK I spoke too soon.
>     I tried this:
>     SELECT (ST_SummaryStats(ST_Union(rast))).sum sum
>     FROM (SELECT ST_MapAlgebra(deposition.rast, concentrated.rast, 'IF
>     ST_UpperleftY(mymodel.deposition.rast) ) foo;
>     And all I get is rast does not exist.
>     I’m afraid the penny has not dropped yet L
>     Darrel
>     *Darrel Maddy
>     *Sent:* 23 November 2015 16:30
>     <mailto:postgis-users at lists.osgeo.org>>
>     Dear Pierre and Rasmus,
>     Many thanks for trying to help.
>     Rasmus: I am aware of GMT but I was looking for a solution in
>     postgis so that I can keep all of the data extraction in one place.
>     Pierre: That is exactly what I was looking for and very many
>     thanks for including the explanation.  I am a little overwhelmed
>     with the number of functions offered in postgis. It is certainly a
>     remarkable tool.  Watching the queries plough through my datasets
>     is a pleasure – albeit the results do not always please me J
>     Hopefully I can put this to work later tonight.
>     Best wishes
>     Darrel
>     *Pierre Racine
>     *Sent:* 23 November 2015 16:17
>     Darrel,
>     1)Create a new raster selecting the right pixels with
>     ST_MapAlgebra(raster, raster)
>     2)Make sure only intersecting rasters are processed by using their
>     upper left corner X and Y coordinates (with ST_UpperLeftX() and
>     UpperLeftY())
>     3)Sum the selected pixels with ST_SummaryStats(rast)
>     All in all a global query should look like this:
>     FFOM (SELECT ST_MapAlgebra(tableA.rast, tableB.rast, 'IF [rast2] >
>     threshold THEN [rast1] ELSE NULLENDIF ' )
>                 FROM tableA, tableB
>                 WHERE ST_UpperleftX(tableA.rast) =
>     ST_UpperleftX(tableB.rast) AND
>                              ST_UpperleftY(tableA.rast) =
>     ST_UpperleftY(tableB.rast) AND
>                              maybe some other condition here if you
>     get time series e.g. tableA.year = tableB.year AND tableA.month =
>     tableB.month) foo
>     If you have millions of tile you could create indexes on
>     ST_UpperleftX(tableA.rast), ST_UpperleftX(tableB.rast),
>     ST_UpperleftY(tableA.rast) and ST_UpperleftY(tableB.rast) to make
>     the query faster.
>     You could also just use WHERE ST_Intersects(tableA.rast,
>     tableB.rast) instead…
>     Pierre
>     *Darrel Maddy
>     *Sent:* Monday, November 23, 2015 7:20 AM
>     *Subject:* [postgis-users] Help with SQL query?
>     Dear all,
>     As you know I am relatively new to postgis and SQL and therefore
>      I have much to learn. However, I am facing a paper deadline and
>     need to do some quick analysis of the data I have and I am
>     struggling to figure out how best to pursue what I need to do.
>     I have a significant number of rasters which have double precision
>     values.  Without going into detail about what the rasters
>     represent, I need to extract and sum values from one set of
>     rasters in say table A based upon  values in another set of
>     rasters in say table B  where the pixel value in the raster from
>     Table B exceeds a threshold. Both tables are the same size
>     (rasters are tiled) but I also need to figure out how I make sure
>     the correct rasters are compared.  They have filenames like this
>     rastervariable_10.tif, rastervariable_100.tif , presumably I need
>     to use a logical expression to strip the numerical value (in this
>     case this represents the year) and then order on that basis?
>     I can do this in QGIS one at a time but that is a little clumsy
>     and rather time consuming.
>     If someone can just point me in the right direction I am sure I
>     can figure out the rest for myself.
>     Apologies once more for asking what is probably a rather trivial
>     question and yet again demonstrating my ignorance.
>     Many thanks
>     Darrel
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/postgis-users
> [At other schools] I think the most common fault in general is to teach students how to pass exams instead of teaching them the science.
> Donald Knuth
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151124/9d1cce18/attachment.html>
