[postgis-users] Help with SQL query?
Birgit Laggner birgit.laggner at ti.bund.de
Tue Nov 24 05:03:40 PST 2015
Thanks for your feedback, Darrel! I hope, your query results will look fine.
Regards,
Birgit
Am 24.11.2015 um 14:00 schrieb Darrel Maddy:
> Dear Birgit,
> Very many thanks. The query is now running – so it is no longer giving
> an error. I will not know for a few hours whether it is calculating
> the necessary values but it seems progress is being made.
> I have a book coming on SQL – I clearly need to do my homework more
> thoroughly J
> I will confirm when it stops!
> Best wishes
> Darrel
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Birgit Laggner
> *Sent:* 24 November 2015 12:19
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] Help with SQL query?
> Hi Darrel,
> my PostGIS version is too old for testing, but if I read the
> documentation right, then your expression has to be SQL. And IF THEN
> ELSE etc. is not SQL as far as I know - SQL has CASE WHEN.
> So, I would assume, you would need to write your expression like this:
> 'CASE WHEN [rast2] > 0.0 THEN [rast1] ELSE NULL END'
> I am curious if this helps with your error...
> Regards,
> Birgit
> Am 24.11.2015 um 10:09 schrieb Darrel Maddy:
>     Dear Roxanne,
>     Many thanks. I did pickup that issue shortly after my last post
>     and it cured the first problem.
>     There is still an SQL issue with the expression however.
>     I tried ‘IF [rast2]>0.0 THEN [rast1] ELSE NULL ENDIF’
>     This produces an error at $2. I can remove that problem by doing this
>     ‘IF ([rast2]>0.0) THEN [rast1] ELSE NULL ENDIF’
>     But then I get the error at THEN
>     Curiously ‘[rast2]+[rast1]’  works as intended so somehow the
>     conditional is being specified incorrectly.
>     Unfortunately there is nothing in the documentation which helps me
>     with this variant.
>     I will keep trying.
>     Darrel
>     [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of
>     *Roxanne Reid-Bennett
>     *Sent:* 24 November, 2015 12:46 AM
>     <mailto:postgis-users at lists.osgeo.org>
>     On 11/23/2015 12:41 PM, Darrel Maddy wrote:
>         Dear Pierre,
>         I was not looking for a total solution and I am grateful for
>         the suggestion.
>         Although it may not look like it, I did consult the
>         documentation and also I have Regina’s book beside me.
>          Unfortunately, for me at least, both documents assume some
>         knowledge of SQL – which I do not have.  I am also trying to
>         do this simultaneously with a large number of other things
>         that are new to me.  I do not find the errors reported at all
>         informative and consider the query I am trying to perform to
>         be relatively trivial and hence I had hoped the structure of
>         the query might have been more intuitive.  For others it may be.
>     FWIW - I don't play with rasters, but this appears to be a pure
>     SQL thing... add "as rast" like below and try again.
>     SELECT ST_MapAlgebra(deposition.rast, concentrated.rast, 'IF
>     concentrated > 6 THEN deposition ELSE NULL ENDIF ' )
>     as rast
>     FROM mymodel.deposition, mymodel.concentrated
>     WHERE ST_UpperleftX(mymodel.deposition.rast) =
>     ST_UpperleftX(mymodel.concentrated.rast) AND
>                              ST_UpperleftY(mymodel.deposition.rast) =
>     Roxanne
>         I will try not to bother you again.
>         Darrel
>         *Pierre Racine
>         *Sent:* 23 November 2015 20:30
>         *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>         The expression has to stay as it was: 'IF [rast2] > threshold
>         THEN [rast1] ELSE NULL ENDIF '
>         Just replace the threshold value as you did.
>         Do not try to replace the [rast2] and [rast1]. They refer to
>         the first and second raster pixel values. Read the
>         ST_Mapalgebra doc…
>         Don’t expect our suggestions to work blindly. I did not test
>         this query. I’m not in your context. I expect you read the doc
>         about all the mentioned functions and adjust for your specific
>         context. I said “your query should “look like” this”…
>         Pierre
>         *Darrel Maddy
>         *Sent:* Monday, November 23, 2015 2:47 PM
>         OK I spoke too soon.
>         I tried this:
>         SELECT (ST_SummaryStats(ST_Union(rast))).sum sum
>         FROM (SELECT ST_MapAlgebra(deposition.rast, concentrated.rast,
>         'IF concentrated > 6 THEN deposition ELSE NULL ENDIF ' )
>         ST_UpperleftY(mymodel.deposition.rast) ) foo;
>         And all I get is rast does not exist.
>         I’m afraid the penny has not dropped yet L
>         Darrel
>         *Darrel Maddy
>         *Sent:* 23 November 2015 16:30
>         <mailto:postgis-users at lists.osgeo.org>>
>         Dear Pierre and Rasmus,
>         Many thanks for trying to help.
>         Rasmus: I am aware of GMT but I was looking for a solution in
>         postgis so that I can keep all of the data extraction in one
>         place.
>         Pierre: That is exactly what I was looking for and very many
>         thanks for including the explanation.  I am a little
>         overwhelmed with the number of functions offered in postgis.
>         It is certainly a remarkable tool.  Watching the queries
>         plough through my datasets is a pleasure – albeit the results
>         do not always please me J
>         Hopefully I can put this to work later tonight.
>         Best wishes
>         Darrel
>         *Pierre Racine
>         *Sent:* 23 November 2015 16:17
>         Darrel,
>         1)Create a new raster selecting the right pixels with
>         ST_MapAlgebra(raster, raster)
>         2)Make sure only intersecting rasters are processed by using
>         their upper left corner X and Y coordinates (with
>         ST_UpperLeftX() and UpperLeftY())
>         3)Sum the selected pixels with ST_SummaryStats(rast)
>         All in all a global query should look like this:
>         FFOM (SELECT ST_MapAlgebra(tableA.rast, tableB.rast, 'IF
>         [rast2] > threshold THEN [rast1] ELSE NULLENDIF ' )
>                     FROM tableA, tableB
>                     WHERE ST_UpperleftX(tableA.rast) =
>         ST_UpperleftX(tableB.rast) AND
>                                  ST_UpperleftY(tableA.rast) =
>         ST_UpperleftY(tableB.rast) AND
>                                  maybe some other condition here if
>         you get time series e.g. tableA.year = tableB.year AND
>         tableA.month = tableB.month) foo
>         If you have millions of tile you could create indexes on
>         ST_UpperleftX(tableA.rast), ST_UpperleftX(tableB.rast),
>         ST_UpperleftY(tableA.rast) and ST_UpperleftY(tableB.rast) to
>         make the query faster.
>         You could also just use WHERE ST_Intersects(tableA.rast,
>         tableB.rast) instead…
>         Pierre
>         *Darrel Maddy
>         *Sent:* Monday, November 23, 2015 7:20 AM
>         *Subject:* [postgis-users] Help with SQL query?
>         Dear all,
>         As you know I am relatively new to postgis and SQL and
>         therefore  I have much to learn. However, I am facing a paper
>         deadline and need to do some quick analysis of the data I have
>         and I am struggling to figure out how best to pursue what I
>         need to do.
>         I have a significant number of rasters which have double
>         precision values.  Without going into detail about what the
>         rasters represent, I need to extract and sum values from one
>         set of rasters in say table A based upon  values in another
>         set of rasters in say table B  where the pixel value in the
>         raster from Table B exceeds a threshold. Both tables are the
>         same size (rasters are tiled) but I also need to figure out
>         how I make sure the correct rasters are compared.  They have
>         filenames like this rastervariable_10.tif,
>         rastervariable_100.tif , presumably I need to use a logical
>         expression to strip the numerical value (in this case this
>         represents the year) and then order on that basis?
>         I can do this in QGIS one at a time but that is a little
>         clumsy and rather time consuming.
>         If someone can just point me in the right direction I am sure
>         I can figure out the rest for myself.
>         Apologies once more for asking what is probably a rather
>         trivial question and yet again demonstrating my ignorance.
>         Many thanks
>         Darrel
>         _______________________________________________
>         postgis-users mailing list
>         postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/postgis-users
>     [At other schools] I think the most common fault in general is to teach students how to pass exams instead of teaching them the science.
>     Donald Knuth
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151124/4d358ed1/attachment.html>
