[postgis-users] Can we limit the search range of geocode() function in Tiger Geocoder?
draco doc dracodoc at gmail.com
Fri Nov 27 17:27:09 PST 2015
Hi all, I asked this question in gis stackexchange here already
<http://gis.stackexchange.com/questions/171817/can-we-limit-the-search-range-of-geocode-function-in-postgis-tiger-geocoder>.
I'm also posting the question in the mailing list to make sure the experts
can see the question.
I found the server with only 2 states data loaded is much faster than the
server with all states loaded. My theory is bad formatted address that
don't have a exact hit at first will cost much more time when the geocoder
checked all states. With only 2 states this search is limited and stopped
much early.
There is a restrict_region parameter in geocode function looks promising if
it can limit the search range, since I have enough information or reason to
believe the state information in my addresses input are correct.
I wrote a query trying to use one state's geometry as the limiting
parameter:
SELECT geocode('501 Fairmount DR , Annapolis, MD 20137', 1, the_geom)
    FROM tiger.state WHERE statefp = '24';
and compared the performance with the simple version
SELECT geocode('501 Fairmount DR , Annapolis, MD 20137',1);
I didn't find performance gain with the parameter. Instead it lost the
performance gain from caching, which usually came from running same query
immediately again because all the needed data have been cached in RAM.
Maybe my usage is not proper, or this parameter is not intended to work as
I expected.
However if the search range can be limited, the performance gain could be
substantial, since it's the bad formatted addresses took the most time to
geocode, and they also often mess up the already cached data because the
geocoder need to search for states, even all my input are in one state and
all data can be cached in RAM.
Thanks!
By the way, I wrote about my system setup
<http://dracodoc.github.io/2015/11/17/Geocoding/> and work flow
<http://dracodoc.github.io/2015/11/19/Script-workflow/> in my blog. Wish it
can help other novices in geocoding.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151127/29ed6de3/attachment.html>
