[postgis-users] How do I handle a ResultSet from a java request?
Andrew Davis
drsockmonkee at gmail.com
Tue Oct 6 06:55:20 PDT 2015
Thanks...
I am just starting out on it. I will be passing only about 40 point
features first.
I will make note of and go look at the stream... as well..
Andy
On Oct 6, 2015 8:53 AM, "Nicolas Ribot" <nicolas.ribot at gmail.com> wrote:
> Hi Andy,
> Your Java ResultSet contains one big row representing your geoJson
> document. You can pass it to the client by building a string from the
> resultset:
> String geojson = resultSet.getString(1);
> Be careful to the potential big size of the String: if you expect a big
> geojson document from the database, it may be wiser to stream it to the
> client from the JDBC connection instead of building a Java String.
> Nicolas
> On 6 October 2015 at 15:32, Andrew Davis <drsockmonkee at gmail.com> wrote:
>> Hi all..
>> I'm sending my first question out so patience please.
>> I've got a working servlet on my server that will query for and get
>> information back from my postgis DB.
>> Up until now I have been just parsing the results and sending back a json
>> string. I want to get a GeoJSON back from my db now.
>> I've been working through the information I found here:
>> http://www.postgresonline.com/journal/archives/267-Creating-GeoJSON-Feature-Collections-with-JSON-and-PostGIS-functions.html
>> I can create the table with locations included and a geog value, and I
>> can run the query below
>> SELECT row_to_json(fc)
>> FROM ( SELECT 'FeatureCollection' As type, array_to_json(array_agg(f)) As features
>> FROM (SELECT 'Feature' As type
>> , ST_AsGeoJSON(lg.geog)::json As geometry
>> , row_to_json((loc_id, loc_name)) As properties
>> FROM locations As lg ) As f ) As fc;
>> which brings back a single line string and is in the correct format all in PGAdmin3.
>> I have been trying to duplicate this from my server with java and am stuck at the point where I have
>> run the query and have a 'thing' (ResultSet) but am unsure as to how to handle it and then pass it
>> back to the client.
>> Any help would be welcome.
>> Andy..
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151006/64274c16/attachment.html>
