[postgis-users] How do I handle a ResultSet from a java request?
Nicolas Ribot
nicolas.ribot at gmail.com
Tue Oct 6 07:01:45 PDT 2015
What kind of client is plugged to your Java code ?
Does it expect a raw json document to process on its own, or a geographic
object built in Java ?
Nicolas
On 6 October 2015 at 15:55, Andrew Davis <drsockmonkee at gmail.com> wrote:
> Thanks...
> I am just starting out on it. I will be passing only about 40 point
> features first.
> I will make note of and go look at the stream... as well..
> Andy
> On Oct 6, 2015 8:53 AM, "Nicolas Ribot" <nicolas.ribot at gmail.com> wrote:
>> Hi Andy,
>> Your Java ResultSet contains one big row representing your geoJson
>> document. You can pass it to the client by building a string from the
>> resultset:
>> String geojson = resultSet.getString(1);
>> Be careful to the potential big size of the String: if you expect a big
>> geojson document from the database, it may be wiser to stream it to the
>> client from the JDBC connection instead of building a Java String.
>> Nicolas
>> On 6 October 2015 at 15:32, Andrew Davis <drsockmonkee at gmail.com> wrote:
>>> Hi all..
>>> I'm sending my first question out so patience please.
>>> I've got a working servlet on my server that will query for and get
>>> information back from my postgis DB.
>>> Up until now I have been just parsing the results and sending back a
>>> json string. I want to get a GeoJSON back from my db now.
>>> I've been working through the information I found here:
>>> http://www.postgresonline.com/journal/archives/267-Creating-GeoJSON-Feature-Collections-with-JSON-and-PostGIS-functions.html
>>> I can create the table with locations included and a geog value, and I
>>> can run the query below
>>> SELECT row_to_json(fc)
>>> FROM ( SELECT 'FeatureCollection' As type, array_to_json(array_agg(f)) As features
>>> FROM (SELECT 'Feature' As type
>>> , ST_AsGeoJSON(lg.geog)::json As geometry
>>> , row_to_json((loc_id, loc_name)) As properties
>>> FROM locations As lg ) As f ) As fc;
>>> which brings back a single line string and is in the correct format all in PGAdmin3.
>>> I have been trying to duplicate this from my server with java and am stuck at the point where I have
>>> run the query and have a 'thing' (ResultSet) but am unsure as to how to handle it and then pass it
>>> back to the client.
>>> Any help would be welcome.
>>> Andy..
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151006/a231f562/attachment.html>
