[postgis-users] PostGIS 2.2.0 build error on Linux.
Sandro Santilli
strk at keybit.net
Tue Oct 13 01:22:48 PDT 2015
On Tue, Oct 13, 2015 at 01:38:15PM +0530, Bandaru Muralikrishna wrote:
> My compiler version is :
> gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-55)
> One more question , is bison 3.0 version required to build PostGIS
> 2.2.0 ? because i got the below build error when i build with bison
> 2.3 version. After upgrade bison to 3.0.4, the build issue got
> resolved. Interestingly build was passed on OS X ( 10.9 ) with bison
> 2.3 version without any build issue.
No bison should be needed by fetching a tarball unless you
run "make maintainer-clean". I haven't tried with 2.2.0 nor
I have a machine to try it otherwise. If you want to file a ticket
for this we can at least document the requirement for development
versions.
--strk;
