[postgis-users] PostGIS 2.2.0 build error on Linux.
Bandaru Muralikrishna bandaru.muralikrishna at enterprisedb.com
Tue Oct 13 04:00:02 PDT 2015
On Tue, Oct 13, 2015 at 1:52 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Oct 13, 2015 at 01:38:15PM +0530, Bandaru Muralikrishna wrote:
>> My compiler version is :
>> gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-55)
>> One more question , is bison 3.0 version required to build PostGIS
>> 2.2.0 ?  because i got the below build error when i build with bison
>> 2.3 version. After upgrade bison to 3.0.4, the build issue got
>> resolved. Interestingly build was passed on OS X  ( 10.9 ) with bison
>> 2.3 version without any build issue.
> No bison should be needed by fetching a tarball unless you
> run "make maintainer-clean". I haven't tried with 2.2.0 nor
> I have a machine to try it otherwise. If you want to file a ticket
> for this we can at least document the requirement for development
> versions.
  This build issue not with bison version specific, problem with my
build script. So no need to do any document for this issue.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
