[postgis-users] perform intersection on large tables
Travis Kirstine traviskirstine at gmail.com
Wed Sep 2 11:32:40 PDT 2015
I'm trying to perform an intersection using two tables, one table contains
a regular grid of polygon geometries the other table contains parcels
polygons.  I need to perform an intersection to extract the parcels as
lines with a label point for each polygon in the grid table.  My novice
approach was to create new table with a generic geometry type and then loop
through each row in the grid table to run the intersection against the
parcels and insert the results into the table.
The approach works OK when dealing with a few records but fails miserably
when run against larger tables
Any suggestions
   CREATE TABLE results (
        id SERIAL,
        pin VARCHAR(9),
        zone VARCHAR,
        base_name VARCHAR(9)
    SELECT AddGeometryColumn('results', 'geom', 4326, 'GEOMETRY', 2 );
    CREATE OR REPLACE FUNCTION genTiles() RETURNS int4 AS '
    DECLARE r RECORD;
    BEGIN
    FOR r IN SELECT * FROM grid_table
        LOOP
            INSERT INTO results (zone, base_name, pin, geom)
            SELECT
                r.zone, r.base_name,
                p.pin,
                ST_Intersection((ST_Dump(ST_Boundary(p.geom))).geom,
r.geom) AS geom
            FROM
                parcel p
            WHERE
                ST_Intersects(p.geom, r.geom);
           INSERT INTO results (pin, zone, base_name, geom)
            SELECT
                p.pin,
                ST_Intersection((ST_Dump(ST_PointOnSurface(p.geom))).geom,
r.geom) AS geom
            FROM
                parcels p
            WHERE
                ST_Intersects(ST_PointOnSurface(p.geom), r.geom);
        END LOOP;
        return 1;
    END;
    ' LANGUAGE plpgsql;
    SELECT genTiles() as output
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150902/0c0c378f/attachment.html>
