[postgis-users] perform intersection on large tables
James Keener
jim at jimkeener.com
Wed Sep 2 13:23:16 PDT 2015
Is there a reason you don't simply join and insist on looping? Index the geometry fields and joining on st_contains or something should have decent performance.
Jim
On September 2, 2015 2:32:40 PM EDT, Travis Kirstine <traviskirstine at gmail.com> wrote:
>I'm trying to perform an intersection using two tables, one table
>contains
>a regular grid of polygon geometries the other table contains parcels
>polygons. I need to perform an intersection to extract the parcels as
>lines with a label point for each polygon in the grid table. My novice
>approach was to create new table with a generic geometry type and then
>loop
>through each row in the grid table to run the intersection against the
>parcels and insert the results into the table.
>The approach works OK when dealing with a few records but fails
>miserably
>when run against larger tables
>Any suggestions
> CREATE TABLE results (
> id SERIAL,
> pin VARCHAR(9),
> zone VARCHAR,
> base_name VARCHAR(9)
> SELECT AddGeometryColumn('results', 'geom', 4326, 'GEOMETRY', 2 );
> CREATE OR REPLACE FUNCTION genTiles() RETURNS int4 AS '
> DECLARE r RECORD;
> BEGIN
> FOR r IN SELECT * FROM grid_table
> LOOP
> INSERT INTO results (zone, base_name, pin, geom)
> SELECT
> r.zone, r.base_name,
> p.pin,
> ST_Intersection((ST_Dump(ST_Boundary(p.geom))).geom,
>r.geom) AS geom
> FROM
> parcel p
> WHERE
> ST_Intersects(p.geom, r.geom);
> INSERT INTO results (pin, zone, base_name, geom)
> SELECT
> p.pin,
> ST_Intersection((ST_Dump(ST_PointOnSurface(p.geom))).geom,
>r.geom) AS geom
> FROM
> parcels p
> WHERE
> ST_Intersects(ST_PointOnSurface(p.geom), r.geom);
> END LOOP;
> return 1;
> END;
> ' LANGUAGE plpgsql;
> SELECT genTiles() as output
>_______________________________________________
>postgis-users mailing list
>postgis-users at lists.osgeo.org
>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150902/e4605a0f/attachment.html>
