[postgis-users] $libdir/postgis-2.1: No such file or directory
Eric Ladner
eric.ladner at gmail.com
Tue Sep 15 04:25:03 PDT 2015
Interesting that is says "$libdir/..." and not "/usr/lib/...".
It almost looks like something in a shell script is surrounded in single
quotes where it should be double and it's not evaluating the "$libdir" into
what it should actually point to.
On Tue, Sep 15, 2015 at 2:53 AM Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> have you check that the postgis-2.1.so file exists somewhere beside the
> compile folder?
> (captain obvious) you may need to restart the postgres server
> (captain obvious) Need admin right when installing postgis, after compile.
> If you compile yourself, some use of the command `ldconfig`
> at the right time may save you.
> Cheers,
> Rémi-C
> 2015-09-14 23:53 GMT+02:00 Devrim Gündüz <devrim at gunduz.org>:
>> Hi,
>> Are you compiling from source? If so, add --enable-raster for extension
>> support.
>> Or better, use RPMs: http://yum.postgreql.org .
>> Regards,
>> On September 15, 2015 12:17:38 AM GMT+03:00, Steve <sdcvass at gmail.com>
>> wrote:
>>> All,
>>> Ive been beating this to death for too long and hope someone can steer me strait.
>>> Freah install of Linux 6.6
>>> Postgresql fresh install 9.3.9
>>> On a closed network but I mined (I think) all the rpm's I need for postgis.
>>> Postgis install nicely but upon create extension, I get $libdir/postgis-2.1: No such file or directory
>>> when running ./pg_config --pkglibdir, I see /var/lib/pgsql/9.3/lib. postgis-2.1 is not there so I copy it there. No matter what, I still get this error.
>>> Any help for an old Oracle guy would be appreciated.
>>> Steve
>>> Sent from my iPhone
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150915/26650c42/attachment.html>
