[postgis-users] How to convert multipolygon to linestring
Piotr Kania p.kania at op.pl
Tue Sep 22 15:14:08 PDT 2015
Hi!
I try to convert my multipolygon layer to multilinestring - here:
http://postgis.refractions.net/docs/ST_ExteriorRing.html
I found example:
"(...)--If you have a table of MULTIPOLYGONs
--and want to return a MULTILINESTRING composed of the exterior rings of
each polygon
SELECT gid, ST_Collect(ST_ExteriorRing(the_geom)) AS erings
     FROM (SELECT gid, (ST_Dump(the_geom)).geom As the_geom
             FROM sometable) As foo
GROUP BY gid;
My postgresql connection calls -"database", schema-"public", default
primary key field - "gid", default geometry field  -"geom", my
multipolygon layer- "poly_layer". How will look sql code above, with my
data- if I'd like to convert "poly_layer" into new multilinestring layer
"line_layer"?
Thanks for response
Regarding
Piotr Kania
