[postgis-users] invalid join selectivity: 179531936.000000
Rémi Cura
remi.cura at gmail.com
Fri Sep 25 01:19:49 PDT 2015
Yep,
I had the same problem
https://trac.osgeo.org/postgis/ticket/2543
The issue is that this bug is hard to reproduce.
As a workaround, you can try to drop and recreate the table :
DROP TABLE
VACUUM FULL ANALYZE
CREATE TABLE
CREATE INDEX
Cheers,
Rémi-C
2015-09-25 1:32 GMT+02:00 Paul J. Caritj <caritj at gmail.com>:
> Hello,
> I am having trouble with what I expected to be a simple query. I have two
> tables, one of census tracts (with a multipolygon geometry column, srid
> 4269), and another of sites (with a point geometry column, srid 4269). I
> want to find the number of sites that are within a tract of more than a
> given population, so I've tried:
> SELECT count(sites.id) FROM sites, census_tracts WHERE AND
> census_tracts.population > 2000 AND ST_Contains(census_tracts.geometry,
> sites.location);
> But when I do this I get: psycopg2.InternalError: invalid join
> selectivity: 179531936.000000.
> Both of the relevant tables have been analyzed and vacuumed.
> The output of postgis_full_version() is
> POSTGIS="2.1.8 r13780" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" RASTER
> I'm using Windows 7.
> Does this ring a bell for anyone?
> Thanks very much!
> -Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150925/594fc1b0/attachment.html>
