[postgis-users] postgis-users Digest, Vol 163, Issue 11
Bistrais, Bob
Bob.Bistrais at maine.gov
Fri Sep 25 05:19:26 PDT 2015
Hi Birgit and David,
Many thanks for your replies. I actually tried what you had suggested. Quoting the variable as '@myvariable' caused the liteal string, @myvariable, to be passed. I also tried casting, but the variable still got passed as an integer, without quots, causing an error.
In order to make it work, I created another field which is an integer field. I populated the new field with the appropriate integer values. This worked, but I would still be interested in finding a way to pas numeric characters as text.
________________________________________
From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of postgis-users-request at lists.osgeo.org [postgis-users-request at lists.osgeo.org]
Sent: Thursday, September 24, 2015 3:00 PM
To: postgis-users at lists.osgeo.org
Subject: postgis-users Digest, Vol 163, Issue 11
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
postgis-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of postgis-users digest..."
Today's Topics:
1. Using string variables with PGScript (Bistrais, Bob)
2. Re: Using string variables with PGScript (David Fawcett)
3. Re: Using string variables with PGScript (Birgit Laggner)
Message: 1
Date: Wed, 23 Sep 2015 21:26:32 +0000
To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Using string variables with PGScript
Message-ID:
<D655A37D8BC306438F87579A672E3D107AEE9906 at OIT-TEAQEXMBX01.som.w2k.state.me.us>
Content-Type: text/plain; charset="us-ascii"
I am having trouble using a variable in a Select statement, using PGScript. I am trying to define a string variable, then use it in the Select statement. Something like this:
DECLARE @MYSTRING;
SET @MYSTRING = CAST(@REC[0]['mycode'] AS STRING); -- at REC was set from a previous select
SELECT * from mytable where myfield = @MYSTRING;
-The variable is not quoted, so the select statement fails. How do I get the string variable to be enclosed in quotes?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150923/43f67cbd/attachment-0001.html>
Message: 2
Date: Wed, 23 Sep 2015 20:43:30 -0500
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Using string variables with PGScript
Message-ID:
<CAF7K3b8x=jEBPMWTa_B4hUOSNK=45tE0nM1xcjyS9wWRmoUodQ at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Bob,
I haven't ever used PGScript, but I wonder one of the postgres quote
functions found on this page might work:
http://www.postgresql.org/docs/9.1/static/functions-string.html
I would try quote_literal()
David.
On Wed, Sep 23, 2015 at 4:26 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
> DECLARE @MYSTRING;
> previous select
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150923/a0ce2539/attachment-0001.html>
Message: 3
Date: Thu, 24 Sep 2015 15:22:42 +0200
From: Birgit Laggner <birgit.laggner at ti.bund.de>
Message-ID: <5603F922.4090801 at ti.bund.de>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Hi Bob,
I would recommend something as simple as
SELECT * from mytable where myfield = '@MYSTRING';
I tried using a string variable in a PGScript once, too, and if I
remember correctly, quote_literal() did not work.
Good luck and regards,
Birgit
Am 24.09.2015 um 03:43 schrieb David Fawcett:
> Bob,
> David.
> DECLARE @MYSTRING;
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150924/8ed2df10/attachment-0001.html>
End of postgis-users Digest, Vol 163, Issue 11
