[postgis-users] Problem updating geometry in a record
Bistrais, Bob
Bob.Bistrais at maine.gov
Mon Sep 28 13:46:30 PDT 2015
I have been able to derive a geometry from a query. I want to insert that geometry into a Multilinestring field. I have some SQL code to do it. When I run the code, the output say that the query was successful. But I don't see the geometry inserted into the table. Here is the code:
update highschools_aroo set routegeom =
(SELECT ST_Union(geom) as mygeom from (SELECT pt.geom
FROM pgr_dijkstra(
'SELECT gid AS id,
sourceroute::integer as source,
targetroute::integer as target,
(feet / 5280)::double precision AS cost,
feet::double precision as reverse_cost
FROM ngrdsaroo2',2465,1713,false,true)
as di
JOIN ngrdsaroo2 pt on di.id2 = pt.gid) as foo)
WHERE source_node = 2465 and target_node = 1713;
-As mentioned, this runs with no errors, but the geometry field is not updated. Any suggestions?
Thanks,
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150928/75b1d083/attachment.html>
