[postgis-users] Problem updating geometry in a record
Birgit Laggner birgit.laggner at ti.bund.de
Tue Sep 29 00:00:22 PDT 2015
Hi Bob,
I had the problem sometimes that st_union() result was NULL. Perhaps
that's the case with your query, too? Is it necessary to use st_union()?
Otherwise you could replace it with st_collect(), if you just want to
collect all geometries into a multilinestring. That's more robust
because no geoprocessing is needed...
Regards,
Birgit
Am 28.09.2015 um 22:46 schrieb Bistrais, Bob:
> I have been able to derive a geometry from a query.  I want to insert
> that geometry into a Multilinestring field.  I have some SQL code to
> do it.  When I run the code, the output say that the query was
> successful. But I don’t see the geometry inserted into the table.
> Here is the code:
> update highschools_aroo set routegeom =
> (SELECT ST_Union(geom) as mygeom from (SELECT pt.geom
>                 FROM pgr_dijkstra(
>                                 'SELECT gid AS id,
> sourceroute::integer as source,
> targetroute::integer as target,
> (feet / 5280)::double precision AS cost,
> feet::double precision as reverse_cost
> FROM ngrdsaroo2',2465,1713,false,true)
> as di
> JOIN ngrdsaroo2 pt on di.id2 = pt.gid) as foo)
> WHERE source_node = 2465 and target_node = 1713;
> -As mentioned, this runs with no errors, but the geometry field is not
> updated.  Any suggestions?
> Thanks,
> Bob
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150929/8bc55f61/attachment.html>
