[postgis-users] Raster tile size impact results
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Aug 9 05:30:25 PDT 2016
What if you remove the ST_Rescale() ?
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
> Of Pierre Bails
> Sent: Thursday, July 28, 2016 4:28 AM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Raster tile size impact results
> Hi,
> The full request is :
> SELECT DISTINCT ST_AsGeojson(ST_Union((px.geom),4326))
> FROM (
>   SELECT *
>   FROM dsm
>     INNER JOIN
> ST_SetSRID(ST_MakeValid(ST_GeomFromGeojson('{"type":"Polygon","coordinat
> es":[[[],[],[],[],[],[]]]}')), 4326) AS geom on ST_Intersects(dsm.rast, geom)
> ) AS inter,
> ST_PixelAsCentroids (ST_Clip(ST_Rescale(inter.rast, 0.5), inter.geom),1) as px
> Thanks,
> Pierre
> Pierre Bails
> GIS Engineer
> Redbird
> EMEA - 16, rue de la Comète - 75007 Paris - France
> US - 44 Tehama St, San Francisco, CA 94105 - USA
> Mobile: +33 677 375 851 | US Office: +1 415 366 0191 | FR Office: +33 184 165
> 201
> bails at getredbird.com <mailto:bails at getredbird.com>  | www.getredbird.com
> <http://www.getredbird.com/>  | Facebook
> <https://www.facebook.com/redbird.drones>  | Twitter
> <https://twitter.com/redbirdHQ>  | Youtube
> <https://www.youtube.com/channel/UC9ab5NnNorfVcRdynbTzSLw/videos>
> Le lun. 25 juil. 2016 à 21:30, Pierre Racine <Pierre.Racine at sbf.ulaval.ca
> <mailto:Pierre.Racine at sbf.ulaval.ca> > a écrit :
> 	I will need to see your last query to try to find the problem.
> 	Pierre
> <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Pierre Bails
> 	Sent: Wednesday, July 20, 2016 5:36 AM
> <mailto:postgis-users at lists.osgeo.org> >
> 	Hi,
> 	Thank you for the tips.
> 	Well, I don't know why, but the st_clip function doesn't seem work fine.
> 	After clipping and dumping each pixel as point, some points follow tiles,
> others follow the geometry. Any idea why ?
> 	For now, to avoid the problem, I apply a St_ContainsProperly after the
> dump.
> 	Red : geometry
> 	Light blue : tiles
> 	Dark blue : pixels as points
> 	Thank you for your help !
> 	Pierre
> 	Le ven. 15 juil. 2016 à 17:28, Pierre Racine <Pierre.Racine at sbf.ulaval.ca
> 		Sorry for the late answer.
> 		You have to vectorize them on the fly from within OpenJump:
> 		SELECT (ST_DumpAsPolygons(rast).* FROM yourrastertable;
> 		If your raster is very big and tiled, just vectorize the tiles you
> need:
> 		SELECT rid, rast::geometry FROM yourrastertable;
> 		Look at the rids and then:
> 		WHERE rid = x or rid = y
> 		Pierre
> bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On
> Behalf
> 		> Of Pierre Bails
> 		> Sent: Friday, June 24, 2016 12:32 PM
> 		> Hello,
> 		> Unfortunatly, I don't find a way to print raster results in
> OpenJump. Can you
> 		> explain me how I can do it ?
> 		> Pierre
> 		> Le lun. 20 juin 2016 à 16:16, Pierre Racine
> <Pierre.Racine at sbf.ulaval.ca <mailto:Pierre.Racine at sbf.ulaval.ca>
> <mailto:Pierre.Racine at sbf.ulaval.ca> > > a écrit :
> 		>       I would try to understand, visually using OpenJump, how
> your tiles are
> 		> clipped in the two cases... I guess sometimes 1 pixel wide tiles
> get clipped in a
> 		> strange way.
> 		>       Pierre
> <mailto:postgis-users-bounces at lists.osgeo.org> > ] On Behalf
> 		>       > Of Pierre Bails
> 		>       > Sent: Wednesday, June 15, 2016 11:41 AM
> 		>       > To: postgis-users at lists.osgeo.org <mailto:postgis-
> users at lists.osgeo.org>  <mailto:postgis- <mailto:postgis->
> 		> users at lists.osgeo.org <mailto:users at lists.osgeo.org> >
> 		>       > Subject: [postgis-users] Raster tile size impact results
> 		>       > Hi all,
> 		>       > I'm looking for get all pixel's value in a raster insert
> thanks to
> 		> raster2pgsql
> 		>       > intersect by a polygon.
> 		>       > Nevertheless, there are some things that I don't
> understand: depends
> 		> on tile
> 		>       > size, I don't have the same result... The error between 2
> raster is also
> 		> correlate
> 		>       > to the pixel size (I assume it's due to the pixel number).
> 		>       > Can you explain me how the tile size can influence the
> final result ?
> 		>       > Here is the query :
> 		>       > SELECT DISTINCT SUM((px).val)
> 		>       > FROM(
> 		>       >   SELECT *
> 		>       >   FROM  mns INNER JOIN
> st_setsrid(st_geomfromgeojson('{"type":"Polygon","coordinates":[[[x,y],[x,y],[x
> 		>       > ,y] ]]}'), 4326) as geom on ST_Intersects(mns.rast, geom)
> 		>       > ) AS clip, ST_PixelAsCentroids (ST_Clip(clip.rast,
> clip.geom),1) AS px;
> 		>       > DSM px size 70cm:
> 		>       > raster2pgsql -a -t 250x250 -s 4326 -F pathToDSM.tiff
> dsmTable (result:
> 		> 46 347
> 		>       > 846)
> 		>       > raster2pgsql -a -t 50x50 -s 4326 -F pathToDSM.tiff
> dsmTable    : 46 382
> 		> 873
> 		>       > Difference: 35027
> 		>       > DSM px size 20cm :
> dsmTable :  567
> 		> 505 888
> dsmTable    : 596
> 		> 897 610
> 		>       > Difference: 29 391 722
> 		>       > If we considere 250x250's result as reference, there is a
> difference of
> 		> 0.07% in
> 		>       > the first case, and 5% in the second. If the polygon area
> increases, the
> 		> error rate
> 		>       > increases.
> 		>       > Thank you,
> 		>       > Pierre
> 		>       _______________________________________________
> 		>       postgis-users mailing list
> users at lists.osgeo.org>  <mailto:postgis-users at lists.osgeo.org <mailto:postgis-
> 		>       http://lists.osgeo.org/mailman/listinfo/postgis-users
> 	postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
