[postgis-users] compatible postgis-java tag for postgis-2.2.0 ?
Phillip Ross phillip.w.g.ross+postgis-users at gmail.com
Tue Aug 9 06:51:46 PDT 2016
This looks like a tagging problem with github.  I'll have to investigate
further, but the tags look to be offset by 1 in the commit history.  Thank
you for bringing this to my attention.
- Phillip
On Tue, Aug 9, 2016 at 3:12 AM, Bandaru Muralikrishna <
bandaru.muralikrishna at enterprisedb.com> wrote:
> Hi,
> I can see '2.2.2-SNAPSHOT' with version tag in pom.xml from 2.2.1 tag (
> https://github.com/postgis/postgis-java/blob/v2.2.1/pom.xml ). SNAPSHOT means
> it is in development process, then why using this even though 2.2.1 is a
> stable tag ? is there any reason for this ?
> On Tue, Nov 17, 2015 at 11:28 PM, Phillip Ross <phillip.w.g.ross+postgis-
> users at gmail.com> wrote:
>> Hi Bandaru... since the split from core, the postgis jdbc extensions
>> are no longer versioned along with the PostGIS core.  The latest
>> release of the the jdbc extensions works fine with postgis-2.2.0.
>> Hope that helps!
>> - Phillip
>> On Tue, Nov 17, 2015 at 8:15 AM, Bandaru Muralikrishna
>> <bandaru.muralikrishna at enterprisedb.com> wrote:
>> > Hi,
>> > I want to build postgis jdbc driver with postgis-2.2.0 sources. I
>> > didn't see any postgis-java related files  with postgis-2.2.0 sources.
>> > The statement from http://postgis.net/source/ link is saying "As of
>> > June 2015, PostGIS JDBC development has been split from PostGIS core
>> > and is now on github."  I can see four tags under postgis-java git hub
>> > repository ( https://github.com/postgis/postgis-java/ ). So which one
>> > is compatible tag for me to build  postgis jdbc driver with
>> > Thanks & Regards
>> > Murali Krishna
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/postgis-users
> Thanks & Regards
> Murali Krishna
> Configuration Management Team
> phone: +919767825021
> Website: www.enterprisedb.com
> EnterpriseDB Blog: http://blogs.enterprisedb.com/
> Follow us on Twitter: http://www.twitter.com/enterprisedb
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160809/bc6e4dd4/attachment.html>
