[postgis-users] GeosIntersects Error
David Haynes
haynesd2 at gmail.com
Wed Aug 17 14:57:02 PDT 2016
Hello,
I am running into an interesting version of the bad topology error.
During a raster/vector overlay I receive the following error:
"GEOSIntersects: TopologyException"
I figure I have some bad topologies in my vector dataset. I run the
following code and receive no records. I don't have any invalid topologies.
with data as
SELECT sgl.id as sample_geog_level_id, gi.id as geog_instance_id, gi.label
as geog_instance_label, gi.code as geog_instance_code,
ST_IsValid(bound.geog::geometry) as valid
FROM sample_geog_levels sgl
inner join geog_instances gi on sgl.id = gi.sample_geog_level_id
inner join boundaries bound on bound.geog_instance_id = gi.id
WHERE sgl.id = 1043
SELECT sample_geog_level_id
FROM data
WHERE valid = FALSE
However whenever I run this I receive the invalid topologies error
WITH geographic_boundaries AS
as geog_instance_label, gi.code as geog_instance_code, bound.geog::geometry
as geom
WHERE sgl.id = 1043
SELECT p.geog_instance_id as geog_id, p.geog_instance_label as place_name,
p.geog_instance_code as place_code, ST_Clip(r.rast, 1, p.geom, True) as rast
FROM geographic_boundaries p inner join landcover.glc2000_tp r on
ST_Intersects(r.rast, 1, p.geom)
I also went through the process of running ST_MakeValid(geom) on my data
into a new table and still encounter the error. What am I missing? This
particular error also spits out an x,y location that changes
-113.02232164290001 43.120535816300048
-126.41517874290001 47.584821516300046
-122.12053589950004 48.281250085500034
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160817/fbe9f7ce/attachment.html>
