[postgis-users] PostGIS limited Query Performance
Nick Ves vesnikos at gmail.com
Tue Feb 16 14:53:12 PST 2016
Before anyone be able to give you a solid advice, I would suggest to post
your query plan as well. I am almost certain that you're accessing your
data using wrong queries.
On Tue, Feb 16, 2016 at 10:46 PM, Mustafa Elbehery <
elbeherymustafa at gmail.com> wrote:
> Hi Folks,
> I am trying to create a benchmark to compare PostGIS against Apache Spark
> performance, in SpatialQuery capabilties for sure.
> I have expected that spark will outperfom, since the data resides in
> memory, unlike PostGIS. However, I am more interested in using PostGIS, for
> the sake of the *rich geometric predicates & functions. *
> However, I have tried to load 6GB only of data into a table, and trying a
> join query with another table. Specifically *ST_Within. *
> Surprisingly, PostGIS was unable to finish the query, for *limit >
> 1000000 . *
> In other words, as long as I limit my query result from *10 till
> 10000000, *the query return result. However, more than this, the query
> never return, I have waited for *50 *minutes on AWS EC2 Instance, with 4
> cores & 16 GB, and *nothing !!*
> I have tried to use Vaccum_Verbose & analyze, the same issue remained.
> Would like to hear any suggestions to solve the problem
> Thanks in advance.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160216/1f0ed531/attachment.html>
