[postgis-users] PostGIS 2.2 Debian package based on Postgresql 9.5 for trusty ( ubuntu 14.04)
Pallavi Sontakke
pallavi.sontakke at 2ndquadrant.com
Wed Feb 17 22:05:06 PST 2016
Hi All,
Thanks for the debian packages for trusty for PostGIS.
As in my current work I am looking to use PostGIS with a custom-built
Postgresql (with some changes on top of Postgresql 9.5.0), I am required to
build PostGIS 2.2.1 from source.
As a first step, am trying to build PostGIS from source for Postgresql 9.5.0
In line, I downloaded postgis-2.2.1.tar.gz from http://postgis.net/source/
However, during './configure' am getting this error:
checking for geos_c.h... yes
checking for initGEOS in -lgeos_c... yes
checking for sfcgal-config... /usr/local/bin/sfcgal-config
configure: error: PostGIS requires SFCGAL >= 1.1.0 (found 1.0.0)
On trusty by default version 1.0.0 of SFCGAL is available. Also in my
previous PostGIS source-build attempt, build of SFCGAL 1.2.1 required CGAL
4.7 and still SFCGAL did not get installed properly. Also I noticed that in
Debian trusty PostGIS packages you uploaded, postgis_sfcgal was missing.
I don't need postgis_sfcgal specifically as such, so ran configure with
option --without-sfcgal.
However, due to it, address_standardizer has also got disabled (It was
available in trusty package you had created). Could you please show me a
way, that address_standardizer can be enabled, even if postgis_sfcgal is
not there?
Thanks,
Pallavi
On 11 February 2016 at 16:07, Pallavi Sontakke <
pallavi.sontakke at 2ndquadrant.com> wrote:
> Hi All,
> I was looking to install PostGIS 2.2 to work with Postgresql 9.5 on my
> trusty system. As I did not find any available debian packages for trusty,
> I was trying to build from PostGIS source. However, even after getting many
> other binaries, could not get all modules of PostGIS working (especially
> postgis_sfcgal and address_standardizer).
> Could you please point me to trusty packages if available? Also, if not,
> could you please let me know when would they be available?
> Thanks,
> Pallavi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160218/6a961725/attachment.html>
