[postgis-users] raster2pgsql
Severin Thaler
sev.thaler at gmail.com
Sat Feb 20 08:52:25 PST 2016
thanx rb, that helped.
just a minor clarification i’m adding:
the problem is not having multiple bands but having multiple subdatasets.
anyway, thanx.
> On Feb 20, 2016, at 5:34 AM, Robert Burgholzer <rburghol at vt.edu> wrote:
> I have converted NetCDF to postgres recently, and I recall the same error message,I was able to overcome it by specifying the Band in the import statement. There may be other aceptable syntaxes, but for my dataset, I successfully used the following (relative humidity band):
> File Name: rtma2p5.2015120411.2dvaranl_ndfd.nc <http://rtma2p5.2015120411.2dvaranl_ndfd.nc/>
> Band (see below for ogrinfo list of bands): RELH_2maboveground
> Target PG Table: rh_tmp
> raster2pgsql cmd: raster2pgsql NETCDF:"rtma2p5.2015120411.2dvaranl_ndfd.nc <http://rtma2p5.2015120411.2dvaranl_ndfd.nc/>":RELH_2maboveground rh_tmp > rh_tmp.sql
> The function gdalinfo will tell you your band names. As to your other question, it is true that it can handle only one Band at a time, and therefore only one "variable". A note however, you listed lat/lon as one of your variables, and that is implicit in the raster cell, in essense, so you can derive lat/lon of the cell centroid if you like in PostgreSQL/PostGIS. I did a blog on extracting raster cell data as vector point here : https://robertwb.wordpress.com/2016/02/20/netcdf-data-and-postgis/ <https://robertwb.wordpress.com/2016/02/20/netcdf-data-and-postgis/>
> HTH
> /r/b
> On Fri, Feb 19, 2016 at 1:47 PM, Severin Thaler <sev.thaler at gmail.com <mailto:sev.thaler at gmail.com>> wrote:
> Dear all,
> i have been trying to use raster2pgsql to ingest a netcdf with multiple variables through:
> raster2pgsql -s 4326 -a -C -M -t 10x10 my_netcdf my_table
> but i get:
> Processing 1/1: my_netcdf
> ERROR: convert_raster: No bands found in raster: my_netcdf
> ERROR: process_rasters: Could not process raster: my_netcdf
> ERROR: Unable to process rasters
> i then extracted a single variable from the netcdf through ‘ncks’ and then tried to ingest
> the single variable netcdf with raster2pgsql and it worked. it also worked with another single variable,
> but as soon as i tried with 2 vars it again didn’t work with the same error.
> so it really seems to be that raster2pgsql can only handle a single variable is that true?
> to be precise, the variables i have are:
> lat(lat), lon(lon), time(time), and only one ‘real’ variable, e.g. temperature(time, lat, lon)
> also, does the dimensions the variable depends on need to be in a certain order, i.e.
> would e.g. temperature(time, lat, lon) not work? and are there any other possible conventions
> that the netcdf has to follow in order for raster2pgsql to work, thanks.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/postgis-users <http://lists.osgeo.org/mailman/listinfo/postgis-users>
> Robert W. Burgholzer
> 'Making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity.' - Charles Mingus
> Athletics: http://athleticalgorithm.wordpress.com/ <http://athleticalgorithm.wordpress.com/>
> Science: http://robertwb.wordpress.com/ <http://robertwb.wordpress.com/>
> Wine: http://reesvineyard.wordpress.com/ <http://reesvineyard.wordpress.com/>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160220/70ab2b1a/attachment.html>
