[postgis-users] pg_restore raster workaround help
Regina Obe
lr at pcorp.us
Tue Jul 19 09:22:32 PDT 2016
Which OS are you on and how did you install PostGIS e.g. via Package manager or by compile?
Which version are you running? The script should have been included from PostGIS 2.2.2+ so it's possible you don't have it if you are not running the latest micro version.
The rtpostgis_proc_set_search_path.sql should have been installed in your PostgreSQL share/contrib/postgis-2.2 folder
If per chance it wasn't or you have an older version, I have attached the file.
The statement ""make sure to install in same schema as your backup was installed in"
Means that if say your postgis is installed in schema postgis (when you backed up), then when you do CREATE EXTENSION postgis
You should again install it in PostGIS schema and the script as well. In hindsight, I probably should have just left that statement out since it causes more confusion than helps.
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Chris Lee
Sent: Monday, July 18, 2016 2:40 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] pg_restore raster workaround help
Has anyone had any luck with <http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore> http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore?
I have backed up a raster only schema coming from 9.4/2.2 going to 9.5/2.2. Can you please clarify "make sure to install in same schema as your backup was installed in" ?
The PostGIS extension is on public and I tried loading just the schema (rasters) before loading the data. How can I find rtpostgis_proc_set_search_path.sql ?
Thanks,
Chris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160719/90e22d85/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160719/90e22d85/attachment.ksh>
