[postgis-users] pg_restore raster workaround help
Chris Lee chris.lee.holcomb at gmail.com
Tue Jul 19 09:57:01 PDT 2016
Thank you, it's there and everything appears to be working. FWIW I'm on
Ubuntu 14.04.4 and used a package manager to install PostGIS 2.2.2 r14797.
As far as the phrase, I suspect that "Please install PostGIS and run script
on the same schema that was used for PostGIS on the database you backed up"
would be slightly more clear. Part of my confusion was that my backup was
only a schema backup, and not the same schema.
Chris
Chris Holcomb
Master in Public Affairs, 2011
Master in Energy and Earth Resources, 2011
cholcomb at mail.utexas.edu
512.496.6942
On Mon, Jul 18, 2016 at 1:39 PM, Chris Lee <chris.lee.holcomb at gmail.com>
wrote:
> Has anyone had any luck with http://postgis
> .net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore?
> I have backed up a raster only schema coming from 9.4/2.2 going to
> 9.5/2.2. Can you please clarify "make sure to install in same schema as
> your backup was installed in" ?
> The PostGIS extension is on public and I tried loading just the schema
> (rasters) before loading the data. How can I find
> rtpostgis_proc_set_search_path.sql ?
> Thanks,
> Chris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160719/1e90e5c0/attachment.html>
