[postgis-users] RHEL 6 PostGIS 9.4 cannot install
Andrew Davis
drsockmonkee at gmail.com
Thu Jul 28 05:51:50 PDT 2016
Good Morning, thanks for the input.
I was able to get the epel-release to install (Thanks again on that part..)
my 'yum install postgis2_94' returns an error of
"Cannot retrieve repository metadata (repmond.xml) for prepository: epel.
Please verify its path and try again
my epel.repo
[epel]
name=Extra Packages for Enterprise Linux 6 - $basearch
#baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch
mirrorlist=
https://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=$basearch
failovermethod=priority
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
[epel-debuginfo]
name=Extra Packages for Enterprise Linux 6 - $basearch - Debug
#baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch/debug
mirrorlist=
https://mirrors.fedoraproject.org/metalink?repo=epel-debug-6&arch=$basearch
enabled=0
gpgcheck=1
[epel-source]
name=Extra Packages for Enterprise Linux 6 - $basearch - Source
#baseurl=http://download.fedoraproject.org/pub/epel/6/SRPMS
mirrorlist=
https://mirrors.fedoraproject.org/metalink?repo=epel-source-6&arch=$basearch
enabled=0
gpgcheck=1
Andy...
On Wed, Jul 27, 2016 at 3:19 PM, Regina Obe <lr at pcorp.us> wrote:
> Sounds like you are missing EPEL repo.
> You can try:
> yum -y install epel-release
> (not sure if that works for RHEL 6 or if you have to get the report)
> Hopefully these directions I wrote up a while ago will help. I tested on
> CentOS but should be much the same for RHEL as well.
> http://www.postgresonline.com/journal/archives/362-An-almost-idiots-guide-to-install-PostgreSQL-9.5,-PostGIS-2.2-and-pgRouting-2.1.0-with-Yum.html
> (Also since you are running 9.4 instead of 9.5, you have to just revise
> your yum to account for that, most of the rest should be the same though)
> Hope that helps,
> Regina
> http://www.postgis.us
> http://postgis.net
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Andrew Davis
> *Sent:* Wednesday, July 27, 2016 3:05 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] RHEL 6 PostGIS 9.4 cannot install
> Hello,
> I have an instance of RHEL 6 with postGRESQL 9.4.8 running. I am able to
> login and create databases (command line and through pgAdmin3).
> Now i am trying to install postGIS..
> My results for 'yum list postgis*' show available rpms..
> postgis2_94.x86_64
> postgis2_94-client.x86_64
> postgis2_94-debuginfo.x86_64
> postgis2_94-devel.x86_64
> postgis2_94-docs.x86_64
> postgis2_94-utils.x86_64
> When I run the command "yum install postgis2_94' I get a lot of errors for
> missing dependencies.
> *Package: postgis2_94-2.1.8-1.rhel6.x86_64 (pgdg94) Requires: hdf5...*
> There are multiple others as well..
> I am more than likely missing something simple, but unable to figure this
> out...
> Have I missed something?.. Any advice is welcome..
> Andy.
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160728/6a293a48/attachment.html>
