[postgis-users] ST_Split with Multilinestring
Birgit Laggner
birgit.laggner at thuenen.de
Wed Jun 15 01:01:11 PDT 2016
Hi Marcin,
thanks for your reply. I don't think, that will provide the results I am
looking for. I am deliberately aggregating all intersecting lines with
ST_Union because otherwise the query would result in several collections
per polygon, each collection containig the st_split result for one of
the intersecting lines (blades). But I want the polygon cut with all blades.
Currently I am trying Marcone's suggestion (although I cannot imagine
why this should solve anything - but you never know until you try, right?).
So, thank you both, Marcin and Marcone!
Regards,
Birgit
Am 15.06.2016 um 09:24 schrieb Marcin Mionskowski:
> On Tue, 14 Jun 2016 15:37:40 +0200, Marcone <marconeperes at gmail.com>
> wrote:
>> 2016-06-14 9:52 GMT-03:00 Birgit Laggner <birgit.laggner at thuenen.de>:
>>> I would like to use the ST_Split function to split polygons from one
>>> table with all intersecting lines from another table. Unfortunately,
>>> I get the following error:
>>> ERROR: Splitting a Polygon by a MultiLineString is unsupported
>>> SQL Status:XX000
>>> This is my query:
>>> select betr_id, (cut).path[1], (cut).geom from (select betr_id,
>>> st_dump(st_split) as cut from (select a.betr_id, ST_Split(a.geom,
>>> st_union(b.geom)) from p_sam.nihb_2013_convex_hull_betr a left join
>>> p_sam.ni_dlm13_aaa_gew_sie_ver_l b on st_intersects(a.geom, b.geom)
>>> group by a.betr_id, a.geom) sel1) sel2;
>>> The Manual contains the following info regarding this problem:
>>> "The function supports splitting a line by (multi)point,
>>> (multi)line
>>> or (multi)polygon boundary, a (multi)polygon by line."
>>> This might mean that I would be able to split a line by
>>> multilinestrings, but a polygon only by single linestrings - is that
>>> correct? Does anyone has a suggestion how I could work around this
>>> problem (aside from looping the ST_Split with some function, DO
>>> block or pgScript after selecting all intersecting linestrings per
>>> polygon)?
>>> Thanks a lot for any helpful suggestions!
>> I'm not sure if I understand your problem, but try use
>> ST_Split(st_multi(a.geom),
>> st_union(b.geom)). I'm not test this, but I think that will solve
>> your problem.
>> Best regards.
> Have you tried to ST_Dump multilinestrings first?
> Using CTE this could look like:
> with
> a as ( --polygon
> select ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) a
> b as ( --multilinestring
> select ST_Union(
> (select ST_MakeLine(ST_MakePoint(10, 10),ST_MakePoint(190,
> 190))),
> (select ST_MakeLine(ST_MakePoint(191, 191),ST_MakePoint(200,
> 200)))
> ) b
> c as ( --multilinestring dump -> 2 separate linestrings
> select (ST_Dump(b)).geom c
> from b
> SELECT ST_AsText(ST_Split(a, c))
> from a,c
> where ST_Intersects(a,c)
> Intersection check is done here on line parts.
> Regards
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
