[postgis-users] ST_Split with Multilinestring
Birgit Laggner
birgit.laggner at thuenen.de
Wed Jun 15 02:10:33 PDT 2016
Dear list,
@Marcone: Unfortunately, the st_multi didn't change anything. The error
message is still the same.
Next, I will try some function from a user example from 2008
(https://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithLineString).
Maybe this will be a workaround.
But I am still wondering why I get the error message at all. I did find
a PostGIS ticket addressing the same functionality
(https://trac.osgeo.org/postgis/ticket/3097) and there is mentioned that
the problem is fixed with PostGIS 2.2.0. My PostGIS version is
"POSTGIS="2.2.1 r14555" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.1,
04 March 2015" GDAL="GDAL 1.11.2, released 2015/02/10" LIBXML="2.9.2"
LIBJSON="0.11.99" TOPOLOGY RASTER". So, I would suppose I shouldn't have
this problem.
Any other ideas?
Thanks and regards,
Birgit
Am 15.06.2016 um 10:01 schrieb Birgit Laggner:
> Hi Marcin,
> thanks for your reply. I don't think, that will provide the results I
> am looking for. I am deliberately aggregating all intersecting lines
> with ST_Union because otherwise the query would result in several
> collections per polygon, each collection containig the st_split result
> for one of the intersecting lines (blades). But I want the polygon cut
> with all blades.
> Currently I am trying Marcone's suggestion (although I cannot imagine
> why this should solve anything - but you never know until you try,
> right?).
> So, thank you both, Marcin and Marcone!
> Regards,
> Birgit
> Am 15.06.2016 um 09:24 schrieb Marcin Mionskowski:
>> On Tue, 14 Jun 2016 15:37:40 +0200, Marcone <marconeperes at gmail.com>
>> wrote:
>>> 2016-06-14 9:52 GMT-03:00 Birgit Laggner <birgit.laggner at thuenen.de>:
>>>> I would like to use the ST_Split function to split polygons from one
>>>> table with all intersecting lines from another table.
>>>> Unfortunately,
>>>> I get the following error:
>>>> ERROR: Splitting a Polygon by a MultiLineString is unsupported
>>>> SQL Status:XX000
>>>> This is my query:
>>>> select betr_id, (cut).path[1], (cut).geom from (select betr_id,
>>>> st_dump(st_split) as cut from (select a.betr_id, ST_Split(a.geom,
>>>> st_union(b.geom)) from p_sam.nihb_2013_convex_hull_betr a left join
>>>> p_sam.ni_dlm13_aaa_gew_sie_ver_l b on st_intersects(a.geom, b.geom)
>>>> group by a.betr_id, a.geom) sel1) sel2;
>>>> The Manual contains the following info regarding this problem:
>>>> "The function supports splitting a line by (multi)point,
>>>> (multi)line
>>>> or (multi)polygon boundary, a (multi)polygon by line."
>>>> This might mean that I would be able to split a line by
>>>> multilinestrings, but a polygon only by single linestrings - is
>>>> that
>>>> correct? Does anyone has a suggestion how I could work around this
>>>> problem (aside from looping the ST_Split with some function, DO
>>>> block or pgScript after selecting all intersecting linestrings per
>>>> polygon)?
>>>> Thanks a lot for any helpful suggestions!
>>> I'm not sure if I understand your problem, but try use
>>> ST_Split(st_multi(a.geom),
>>> st_union(b.geom)). I'm not test this, but I think that will solve
>>> your problem.
>>> Best regards.
>> Have you tried to ST_Dump multilinestrings first?
>> Using CTE this could look like:
>> with
>> a as ( --polygon
>> select ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) a
>> b as ( --multilinestring
>> select ST_Union(
>> (select ST_MakeLine(ST_MakePoint(10, 10),ST_MakePoint(190,
>> 190))),
>> (select ST_MakeLine(ST_MakePoint(191, 191),ST_MakePoint(200,
>> 200)))
>> ) b
>> c as ( --multilinestring dump -> 2 separate linestrings
>> select (ST_Dump(b)).geom c
>> from b
>> SELECT ST_AsText(ST_Split(a, c))
>> from a,c
>> where ST_Intersects(a,c)
>> Intersection check is done here on line parts.
>> Regards
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
