[postgis-users] ST_Split with Multilinestring
Marcin Mionskowski
mionskowskimarcin at gmail.com
Wed Jun 15 02:27:42 PDT 2016
I think I finaly understand what you have and what you want to achieve - take a look at polygon and multiline definitions :)
If I'm right, this function should do the work:
create table polygon
id serial,
geom geometry,
done smallint default 0
create table multiline
id serial,
geom geometry,
create table line
id serial,
geom geometry,
insert into polygon (geom)
select ST_Buffer(ST_GeomFromText('POINT(10 10)'), 10);
insert into multiline (geom)
select ST_Union(
(select ST_MakeLine(ST_MakePoint(0, 1),ST_MakePoint(20, 21))),
(select ST_MakeLine(ST_MakePoint(1, 0),ST_MakePoint(20, 19)))
create or replace function test() returns void as
$BODY$
declare ln geometry;
i int;
BEGIN
truncate table line;
insert into line (geom)
select (ST_Dump(geom)).geom
from multiline;
loop
select geom,id
into ln,i
from line
where done=0
limit 1;
with
del as (
delete from polygon p
where ST_Intersects(p.geom,ln)
returning p.geom
select (st_dump(st_split(del.geom,ln))).geom
from del;
update line
set done=1
where id=i;
exit when i is null;
end loop;
end;
$BODY$
LANGUAGE plpgsql;
select test();
On Wed, 15 Jun 2016 11:10:33 +0200, Birgit Laggner <birgit.laggner at thuenen.de> wrote:
> Dear list,
> @Marcone: Unfortunately, the st_multi didn't change anything. The error
> message is still the same.
> Next, I will try some function from a user example from 2008
> (https://trac.osgeo.org/postgis/wiki/UsersWikiSplitPolygonWithLineString).
> Maybe this will be a workaround.
> But I am still wondering why I get the error message at all. I did find
> a PostGIS ticket addressing the same functionality
> (https://trac.osgeo.org/postgis/ticket/3097) and there is mentioned that
> the problem is fixed with PostGIS 2.2.0. My PostGIS version is
> "POSTGIS="2.2.1 r14555" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.1,
> 04 March 2015" GDAL="GDAL 1.11.2, released 2015/02/10" LIBXML="2.9.2"
> LIBJSON="0.11.99" TOPOLOGY RASTER". So, I would suppose I shouldn't have
> this problem.
> Any other ideas?
> Thanks and regards,
> Birgit
> Am 15.06.2016 um 10:01 schrieb Birgit Laggner:
>> Hi Marcin,
>> thanks for your reply. I don't think, that will provide the results I
>> am looking for. I am deliberately aggregating all intersecting lines
>> with ST_Union because otherwise the query would result in several
>> collections per polygon, each collection containig the st_split result
>> for one of the intersecting lines (blades). But I want the polygon cut
>> with all blades.
>> Currently I am trying Marcone's suggestion (although I cannot imagine
>> why this should solve anything - but you never know until you try,
>> right?).
>> So, thank you both, Marcin and Marcone!
>> Regards,
>> Birgit
>> Am 15.06.2016 um 09:24 schrieb Marcin Mionskowski:
>>> On Tue, 14 Jun 2016 15:37:40 +0200, Marcone <marconeperes at gmail.com>
>>> wrote:
>>>> 2016-06-14 9:52 GMT-03:00 Birgit Laggner <birgit.laggner at thuenen.de>:
>>>>> I would like to use the ST_Split function to split polygons from one
>>>>> table with all intersecting lines from another table.
>>>>> Unfortunately,
>>>>> I get the following error:
>>>>> ERROR: Splitting a Polygon by a MultiLineString is unsupported
>>>>> SQL Status:XX000
>>>>> This is my query:
>>>>> select betr_id, (cut).path[1], (cut).geom from (select betr_id,
>>>>> st_dump(st_split) as cut from (select a.betr_id, ST_Split(a.geom,
>>>>> st_union(b.geom)) from p_sam.nihb_2013_convex_hull_betr a left join
>>>>> p_sam.ni_dlm13_aaa_gew_sie_ver_l b on st_intersects(a.geom, b.geom)
>>>>> group by a.betr_id, a.geom) sel1) sel2;
>>>>> The Manual contains the following info regarding this problem:
>>>>> "The function supports splitting a line by (multi)point,
>>>>> (multi)line
>>>>> or (multi)polygon boundary, a (multi)polygon by line."
>>>>> This might mean that I would be able to split a line by
>>>>> multilinestrings, but a polygon only by single linestrings - is
>>>>> that
>>>>> correct? Does anyone has a suggestion how I could work around this
>>>>> problem (aside from looping the ST_Split with some function, DO
>>>>> block or pgScript after selecting all intersecting linestrings per
>>>>> polygon)?
>>>>> Thanks a lot for any helpful suggestions!
>>>> I'm not sure if I understand your problem, but try use
>>>> ST_Split(st_multi(a.geom),
>>>> st_union(b.geom)). I'm not test this, but I think that will solve
>>>> your problem.
>>>> Best regards.
>>> Have you tried to ST_Dump multilinestrings first?
>>> Using CTE this could look like:
>>> with
>>> a as ( --polygon
>>> select ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) a
>>> b as ( --multilinestring
>>> select ST_Union(
>>> (select ST_MakeLine(ST_MakePoint(10, 10),ST_MakePoint(190,
>>> 190))),
>>> (select ST_MakeLine(ST_MakePoint(191, 191),ST_MakePoint(200,
>>> 200)))
>>> ) b
>>> c as ( --multilinestring dump -> 2 separate linestrings
>>> select (ST_Dump(b)).geom c
>>> from b
>>> SELECT ST_AsText(ST_Split(a, c))
>>> from a,c
>>> where ST_Intersects(a,c)
>>> Intersection check is done here on line parts.
>>> Regards
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/postgis-users
Using Opera's mail client: http://www.opera.com/mail/
