[postgis-users] add raster constraint exceeds array size limit
Bborie Park
dustymugs at gmail.com
Fri Mar 11 07:53:29 PST 2016
Wow... that's new. I'm guessing that the array that collects the individual
tiles' extents is getting too big. Can you file a ticket?
On Fri, Mar 11, 2016 at 12:08 AM, Caitríona Smith <kit at hypostasis.com>
wrote:
> Hi All
> I’ve a number of largish rasters that I’m wanting to tile to relatively
> small tiles, but I’m hitting the array limit on the add maximum extent
> constraint.
> If the tile_size is 32x32 or 50x50 I get the error, but a tile size of
> 64x64 completes.
> At 50x50 there are 13M rows and at 64x64 there are 8M
> I’m wanting to use fairly small tiles as I am intending to version control
> the data at the tile level, and would prefer to keep the area that doesn’t
> change under control to a minimum.
> I’m thinking that I might be able to get away with a parent child
> relationship, and that I may have to do that anyway, for performance, but
> I’m not sure what the effect of that will be on the extent constraint.
> Is there something else that I am doing wrong, or is there another way
> around this (I’ve not really looked at the component functions to see what
> they do)
> I’m running postgis 2.2.1 on postgres 9.5.1 on SL7.2 for my sins
> select version();
> version
> PostgreSQL 9.5.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5
> 20150623 (
> Red Hat 4.8.5-4), 64-bit
> (1 row)
> select postgis_full_version();
> post
> gis_full_version
> POSTGIS="2.2.1 r14555" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.8.0, 6
> March
> 2012" GDAL="GDAL 1.11.4, released 2016/01/25" LIBXML="2.9.1"
> LIBJSON="0.11" TOPO
> LOGY RASTER
> (1 row)
> hmdb=> select count(*) from dtm2015_50x50;
> count
> 13360464
> (1 row)
> hmdb=> select count(*) from dtm2015;
> count
> 8152320
> (1 row)
> hmdb=> select addrasterconstraints('dtm2015_50x50'::name, 'rast'::name);
> NOTICE: Adding SRID constraint
> CONTEXT: PL/pgSQL function
> addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean)
> line 53 at RETURN
> NOTICE: Adding scale-X constraint
> line 53 at RETURN
> NOTICE: Adding scale-Y constraint
> line 53 at RETURN
> NOTICE: Adding blocksize-X constraint
> line 53 at RETURN
> NOTICE: Adding blocksize-Y constraint
> line 53 at RETURN
> NOTICE: Adding alignment constraint
> line 53 at RETURN
> NOTICE: Adding number of bands constraint
> line 53 at RETURN
> NOTICE: Adding pixel type constraint
> line 53 at RETURN
> NOTICE: Adding nodata value constraint
> line 53 at RETURN
> NOTICE: Adding out-of-database constraint
> line 53 at RETURN
> NOTICE: Adding maximum extent constraint
> line 53 at RETURN
> ERROR: array size exceeds the maximum allowed (1073741823)
> CONTEXT: SQL statement "SELECT
> st_ashexewkb(st_envelope(st_collect(st_envelope(rast)))) FROM
> cjsmith.dtm2015_50x50"
> PL/pgSQL function _add_raster_constraint_extent(name,name,name) line 20 at
> EXECUTE
> PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 104 at
> assignment
> PL/pgSQL function
> line 53 at RETURN
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160311/73e46548/attachment.html>
