[postgis-users] add raster constraint exceeds array size limit
Caitríona Smith kit at hypostasis.com
Fri Mar 11 10:02:15 PST 2016
Thank you
I’ve filed this as a defect 3501
regards
—kit
> On 11 Mar 2016, at 15:53, Bborie Park <dustymugs at gmail.com> wrote:
> Wow... that's new. I'm guessing that the array that collects the individual tiles' extents is getting too big. Can you file a ticket?
> On Fri, Mar 11, 2016 at 12:08 AM, Caitríona Smith <kit at hypostasis.com <mailto:kit at hypostasis.com>> wrote:
> Hi All
> I’ve a number of largish rasters that I’m wanting to tile to relatively small tiles, but I’m hitting the array limit on the add maximum extent constraint.
> If the tile_size is 32x32 or 50x50 I get the error, but a tile size of 64x64 completes.
> At 50x50 there are 13M rows and at 64x64 there are 8M
> I’m wanting to use fairly small tiles as I am intending to version control the data at the tile level, and would prefer to keep the area that doesn’t change under control to a minimum.
> I’m thinking that I might be able to get away with a parent child relationship, and that I may have to do that anyway, for performance, but I’m not sure what the effect of that will be on the extent constraint.
> Is there something else that I am doing wrong, or is there another way around this (I’ve not really looked at the component functions to see what they do)
> I’m running postgis 2.2.1 on postgres 9.5.1 on SL7.2 for my sins
> select version();
>                                                  version
>  PostgreSQL 9.5.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (
> Red Hat 4.8.5-4), 64-bit
> (1 row)
> select postgis_full_version();
>        post
> gis_full_version
>  POSTGIS="2.2.1 r14555" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.11.4, released 2016/01/25" LIBXML="2.9.1" LIBJSON="0.11" TOPO
> LOGY RASTER
> (1 row)
> hmdb=> select count(*) from dtm2015_50x50;
>   count
>  13360464
> (1 row)
> hmdb=> select count(*) from dtm2015;
>   count
>  8152320
> (1 row)
> hmdb=> select addrasterconstraints('dtm2015_50x50'::name, 'rast'::name);
> NOTICE:  Adding SRID constraint
> CONTEXT:  PL/pgSQL function addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean) line 53 at RETURN
> NOTICE:  Adding scale-X constraint
> NOTICE:  Adding scale-Y constraint
> NOTICE:  Adding blocksize-X constraint
> NOTICE:  Adding blocksize-Y constraint
> NOTICE:  Adding alignment constraint
> NOTICE:  Adding number of bands constraint
> NOTICE:  Adding pixel type constraint
> NOTICE:  Adding nodata value constraint
> NOTICE:  Adding out-of-database constraint
> NOTICE:  Adding maximum extent constraint
> ERROR:  array size exceeds the maximum allowed (1073741823)
> CONTEXT:  SQL statement "SELECT st_ashexewkb(st_envelope(st_collect(st_envelope(rast)))) FROM cjsmith.dtm2015_50x50"
> PL/pgSQL function _add_raster_constraint_extent(name,name,name) line 20 at EXECUTE
> PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 104 at assignment
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/postgis-users <http://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160311/0d78ae95/attachment.html>
