[postgis-users] Query/View permission deny - strange behaviour
Birgit Laggner
birgit.laggner at thuenen.de
Fri May 13 02:17:33 PDT 2016
Hi Pietro,
you try to grant permissions to user catasto_admins - maybe the problem
lies here? You don't write about permission settings for catasto_admins,
so I can't be sure.
Regards,
Birgit
Am 11.05.2016 um 12:39 schrieb Pietro Rossin:
> Hello
> I have problems with postgres/postgis query/view permissions.
> Postgresql 9.4 Postgis 2.1
> I created a user pippo inherit.
> I created a group catasto_editors inherit and a group basi_viewers.
> I granted catasto_editors to pippo and basi_viewers to catasto_editors.
> Then two schemas basi and catasto
> GRANT USAGE ON SCHEMA catasto TO catasto_editors;
> GRANT USAGE ON SCHEMA basi TO basi_viewers;
> All tables/views in catasto are selectable/editable/updateable ecc ecc by
> catasto_editors.
> All tables/views in basi are selectable by basi_viewers.
> Then I made a view in catasto
> CREATE OR REPLACE VIEW catasto.points_in_polygons AS
> SELECT a.id,
> b.name,
> b.code,
> a.id_impianto,
> a.......
> FROM catasto.points a,
> basi.polygons b
> WHERE st_contains(b.geom, a.geom);
> ALTER TABLE catasto.points_in_polygons OWNER TO catasto_admins;
> GRANT ALL ON TABLE catasto.points_in_polygons TO catasto_admins;
> GRANT SELECT, UPDATE, INSERT, DELETE, TRIGGER ON TABLE
> catasto.points_in_polygons TO catasto_editors;
> This doesn't work, an error occurs saying "ERROR: permission denied for
> relation polygons SQL state: 42501"
> Strange thing, if I execute:
> SELECT a.id,
> b.name,
> b.code,
> a.id_impianto,
> a.......
> basi.polygons b
> the query itself works...
> Also if I execute
> SELECT count(id)
> FROM basi.polygons;
> I get the item count..
> Where is my mistake?
> Thanks
> Pietro
> View this message in context: http://postgis.17.x6.nabble.com/Query-View-permission-deny-strange-behaviour-tp5010068.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
