[postgis-users] Query/View permission deny - strange behaviour
Pietro Rossin
pietro.rossin at arpa.fvg.it
Mon May 16 03:34:14 PDT 2016
Hello, I'm going crazy with this problems...
I'll report real names and statements
*Here is the user login pippo *
CREATE ROLE pippo LOGIN NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE
NOREPLICATION;
GRANT sitarpa_catasto_scarichi_editors_ud TO pippo;
GRANT sitarpa_viewers TO pippo;
*Here is the db admin role group*
CREATE ROLE sitarpa_admins NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE
NOREPLICATION;
GRANT sitarpa_basi_amministrative_admins TO sitarpa_admins;
GRANT sitarpa_catasto_scarichi_admins TO sitarpa_admins;
and some others....
*Here the role group sitarpa_catasto_scarichi_editors_ud:*
CREATE ROLE sitarpa_catasto_scarichi_editors_ud
NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE NOREPLICATION;
*Here the role group sitarpa_viewers:*
CREATE ROLE sitarpa_viewers
NOSUPERUSER NOINHERIT NOCREATEDB NOCREATEROLE NOREPLICATION;
*Here is the first schema called basi_amministrative*
CREATE SCHEMA basi_amministrative AUTHORIZATION sitarpa_admins;
GRANT ALL ON SCHEMA basi_amministrative TO sitarpa_admins;
GRANT USAGE ON SCHEMA basi_amministrative TO
sitarpa_basi_amministrative_admins;
sitarpa_basi_amministrative_editors;
sitarpa_basi_amministrative_viewers;
GRANT USAGE ON SCHEMA basi_amministrative TO sitarpa_viewers;
GRANT USAGE ON SCHEMA basi_amministrative TO pippo;
ALTER DEFAULT PRIVILEGES IN SCHEMA basi_amministrative
GRANT INSERT, SELECT, UPDATE, DELETE, TRUNCATE, REFERENCES, TRIGGER ON
TABLES
TO sitarpa_basi_amministrative_admins;
GRANT INSERT, SELECT, UPDATE, DELETE, TRIGGER ON TABLES
TO sitarpa_basi_amministrative_editors;
GRANT SELECT ON TABLES
TO sitarpa_basi_amministrative_viewers;
GRANT USAGE ON SEQUENCES
*Here is the schema catasto_scarichi:*
CREATE SCHEMA catasto_scarichi AUTHORIZATION sitarpa_admins;
GRANT ALL ON SCHEMA catasto_scarichi TO sitarpa_admins;
GRANT USAGE ON SCHEMA catasto_scarichi TO sitarpa_catasto_scarichi_admins;
GRANT USAGE ON SCHEMA catasto_scarichi TO sitarpa_catasto_scarichi_editors;
GRANT USAGE ON SCHEMA catasto_scarichi TO sitarpa_catasto_scarichi_viewers;
sitarpa_catasto_scarichi_editors_ud;
ALTER DEFAULT PRIVILEGES IN SCHEMA catasto_scarichi
TABLES
GRANT SELECT, UPDATE, USAGE ON SEQUENCES
*Here is the first table in the problemathic view:*
CREATE TABLE basi_amministrative.comuni_fvg_2014_3004
id serial NOT NULL,
geom geometry(MultiPolygonZ,3004),
nome character varying(255),
cod_istat character varying(255),
CONSTRAINT comuni_fvg_2014_3004_pkey PRIMARY KEY (id)
WITH (
OIDS=FALSE
ALTER TABLE basi_amministrative.comuni_fvg_2014_3004 OWNER TO
GRANT ALL ON TABLE basi_amministrative.comuni_fvg_2014_3004 TO
GRANT SELECT, UPDATE, INSERT, DELETE, TRIGGER ON TABLE
GRANT SELECT ON TABLE basi_amministrative.comuni_fvg_2014_3004 TO
sitarpa_viewers;
GRANT SELECT ON TABLE basi_amministrative.comuni_fvg_2014_3004 TO pippo;
-- Index: basi_amministrative.sidx_comuni_fvg_2014_3004_geom
-- DROP INDEX basi_amministrative.sidx_comuni_fvg_2014_3004_geom;
CREATE INDEX sidx_comuni_fvg_2014_3004_geom
ON basi_amministrative.comuni_fvg_2014_3004
USING gist
(geom);
*Here is the second table in the view*
CREATE TABLE catasto_scarichi.a_punti_scarico_sfioratori
id serial NOT NULL,
geom geometry(Point,3004),
id_impianto integer,
tipo character varying(255) DEFAULT 1,
scarico_su character varying(50) DEFAULT 5,
cod_ci_sup character varying(50),
cod_ci_sott character varying(50),
bacino_elementare character varying(50),
codice_lims character varying(20),
posizione_corretta boolean DEFAULT false,
codice_scarico character varying(50),
cod_asta_reg character varying(50),
note character varying(500),
utente_inser character varying(50),
utente_modif character varying(50),
data_modif timestamp(0) without time zone,
data_inser timestamp(0) without time zone,
tipo_bacino_elem character varying(50),
tipo_ci_superficiale character varying(50),
CONSTRAINT a_punti_scarico_sfioratori_pkey PRIMARY KEY (id)
WITH (
OIDS=FALSE
ALTER TABLE catasto_scarichi.a_punti_scarico_sfioratori
OWNER TO sitarpa_catasto_scarichi_admins;
GRANT ALL ON TABLE catasto_scarichi.a_punti_scarico_sfioratori TO
GRANT SELECT ON TABLE catasto_scarichi.a_punti_scarico_sfioratori TO
-- Index: catasto_scarichi.sidx_a_punti_scarico_sfioratori_geom
-- DROP INDEX catasto_scarichi.sidx_a_punti_scarico_sfioratori_geom;
CREATE INDEX sidx_a_punti_scarico_sfioratori_geom
ON catasto_scarichi.a_punti_scarico_sfioratori
USING gist
(geom);
*Here is the view...*
CREATE OR REPLACE VIEW catasto_scarichi.scarichi_comuni AS
SELECT a.id,
b.nome,
b.cod_istat,
a.id_impianto,
a.tipo,
a.scarico_su,
a.cod_ci_sup,
a.cod_ci_sott,
a.bacino_elementare,
a.codice_lims,
a.posizione_corretta,
a.codice_scarico,
a.utente_inser,
a.data_inser,
a.utente_modif,
a.data_modif,
a.cod_asta_reg
FROM catasto_scarichi.a_punti_scarico_sfioratori a,
basi_amministrative.comuni_fvg_2014_3004 b
WHERE st_contains(b.geom, a.geom);
ALTER TABLE catasto_scarichi.scarichi_comuni
GRANT ALL ON TABLE catasto_scarichi.scarichi_comuni TO
catasto_scarichi.scarichi_comuni TO sitarpa_catasto_scarichi_editors;
GRANT SELECT ON TABLE catasto_scarichi.scarichi_comuni TO
GRANT SELECT ON TABLE catasto_scarichi.scarichi_comuni TO pippo;
If I select it, both as pippo and as a member of sitarpa_admins, an error
rises saying:
ERROR: permission denied for relation comuni_fvg_2014_3004
If I open a query window and execute:
SELECT a.id,
b.nome,
b.cod_istat,
a.id_impianto,
a.tipo,
a.scarico_su,
a.cod_ci_sup,
a.cod_ci_sott,
a.codice_lims,
a.codice_scarico,
a.utente_inser,
a.data_inser,
a.utente_modif,
a.data_modif,
a.cod_asta_reg
No error is given and data are retrieved, both for pippo and sitarpa_admins
member..
Where is my mistake??
Thanks!
pietro
View this message in context: http://postgis.17.x6.nabble.com/Query-View-permission-deny-strange-behaviour-tp5010068p5010075.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
