[postgis-users] Query/View permission deny - strange behaviour
Ben Madin ben at ausvet.com.au
Tue May 17 14:44:56 PDT 2016
What do you mean:
If I select it, both as pippo and as a member of sitarpa_admins, an error
rises saying:
ERROR: permission denied for relation comuni_fvg_2014_3004
How do you "select" it?
Cheers
Ben
On Monday, 16 May 2016, Pietro Rossin <pietro.rossin at arpa.fvg.it> wrote:
> Hello, I'm going crazy with this problems...
> I'll report real names and statements
> *Here is the user login pippo *
> CREATE ROLE pippo LOGIN NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE
> NOREPLICATION;
> GRANT sitarpa_catasto_scarichi_editors_ud TO pippo;
> GRANT sitarpa_viewers TO pippo;
> *Here is the db admin role group*
> CREATE ROLE sitarpa_admins NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE
> NOREPLICATION;
> GRANT sitarpa_basi_amministrative_admins TO sitarpa_admins;
> GRANT sitarpa_catasto_scarichi_admins TO sitarpa_admins;
> and some others....
> *Here the role group sitarpa_catasto_scarichi_editors_ud:*
> CREATE ROLE sitarpa_catasto_scarichi_editors_ud
>   NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE NOREPLICATION;
> *Here the role group sitarpa_viewers:*
> CREATE ROLE sitarpa_viewers
>   NOSUPERUSER NOINHERIT NOCREATEDB NOCREATEROLE NOREPLICATION;
> *Here is the first schema called basi_amministrative*
> CREATE SCHEMA basi_amministrative  AUTHORIZATION sitarpa_admins;
> GRANT ALL ON SCHEMA basi_amministrative TO sitarpa_admins;
> GRANT USAGE ON SCHEMA basi_amministrative TO
> sitarpa_basi_amministrative_admins;
> sitarpa_basi_amministrative_editors;
> sitarpa_basi_amministrative_viewers;
> GRANT USAGE ON SCHEMA basi_amministrative TO sitarpa_viewers;
> GRANT USAGE ON SCHEMA basi_amministrative TO pippo;
> ALTER DEFAULT PRIVILEGES IN SCHEMA basi_amministrative
>     GRANT INSERT, SELECT, UPDATE, DELETE, TRUNCATE, REFERENCES, TRIGGER ON
> TABLES
>     TO sitarpa_basi_amministrative_admins;
>     GRANT INSERT, SELECT, UPDATE, DELETE, TRIGGER ON TABLES
>     TO sitarpa_basi_amministrative_editors;
>     GRANT SELECT ON TABLES
>     TO sitarpa_basi_amministrative_viewers;
>     GRANT USAGE ON SEQUENCES
> *Here is the schema catasto_scarichi:*
> CREATE SCHEMA catasto_scarichi   AUTHORIZATION sitarpa_admins;
> GRANT ALL ON SCHEMA catasto_scarichi TO sitarpa_admins;
> GRANT USAGE ON SCHEMA catasto_scarichi TO sitarpa_catasto_scarichi_admins;
> GRANT USAGE ON SCHEMA catasto_scarichi TO sitarpa_catasto_scarichi_editors;
> GRANT USAGE ON SCHEMA catasto_scarichi TO sitarpa_catasto_scarichi_viewers;
> sitarpa_catasto_scarichi_editors_ud;
> ALTER DEFAULT PRIVILEGES IN SCHEMA catasto_scarichi
> TABLES
>     GRANT SELECT, UPDATE, USAGE ON SEQUENCES
> *Here is the first table in the problemathic view:*
> CREATE TABLE basi_amministrative.comuni_fvg_2014_3004
>   id serial NOT NULL,
>   geom geometry(MultiPolygonZ,3004),
>   nome character varying(255),
>   cod_istat character varying(255),
>   CONSTRAINT comuni_fvg_2014_3004_pkey PRIMARY KEY (id)
> WITH (
>   OIDS=FALSE
> ALTER TABLE basi_amministrative.comuni_fvg_2014_3004  OWNER TO
> GRANT ALL ON TABLE basi_amministrative.comuni_fvg_2014_3004 TO
> GRANT SELECT, UPDATE, INSERT, DELETE, TRIGGER ON TABLE
> GRANT SELECT ON TABLE basi_amministrative.comuni_fvg_2014_3004 TO
> sitarpa_viewers;
> GRANT SELECT ON TABLE basi_amministrative.comuni_fvg_2014_3004 TO pippo;
> -- Index: basi_amministrative.sidx_comuni_fvg_2014_3004_geom
> -- DROP INDEX basi_amministrative.sidx_comuni_fvg_2014_3004_geom;
> CREATE INDEX sidx_comuni_fvg_2014_3004_geom
>   ON basi_amministrative.comuni_fvg_2014_3004
>   USING gist
>   (geom);
> *Here is the second table in the view*
> CREATE TABLE catasto_scarichi.a_punti_scarico_sfioratori
>   id serial NOT NULL,
>   geom geometry(Point,3004),
>   id_impianto integer,
>   tipo character varying(255) DEFAULT 1,
>   scarico_su character varying(50) DEFAULT 5,
>   cod_ci_sup character varying(50),
>   cod_ci_sott character varying(50),
>   bacino_elementare character varying(50),
>   codice_lims character varying(20),
>   posizione_corretta boolean DEFAULT false,
>   codice_scarico character varying(50),
>   cod_asta_reg character varying(50),
>   note character varying(500),
>   utente_inser character varying(50),
>   utente_modif character varying(50),
>   data_modif timestamp(0) without time zone,
>   data_inser timestamp(0) without time zone,
>   tipo_bacino_elem character varying(50),
>   tipo_ci_superficiale character varying(50),
>   CONSTRAINT a_punti_scarico_sfioratori_pkey PRIMARY KEY (id)
> WITH (
>   OIDS=FALSE
> ALTER TABLE catasto_scarichi.a_punti_scarico_sfioratori
>   OWNER TO sitarpa_catasto_scarichi_admins;
> GRANT ALL ON TABLE catasto_scarichi.a_punti_scarico_sfioratori TO
> GRANT SELECT ON TABLE catasto_scarichi.a_punti_scarico_sfioratori TO
> -- Index: catasto_scarichi.sidx_a_punti_scarico_sfioratori_geom
> -- DROP INDEX catasto_scarichi.sidx_a_punti_scarico_sfioratori_geom;
> CREATE INDEX sidx_a_punti_scarico_sfioratori_geom
>   ON catasto_scarichi.a_punti_scarico_sfioratori
>   USING gist
>   (geom);
> *Here is the view...*
> CREATE OR REPLACE VIEW catasto_scarichi.scarichi_comuni AS
>  SELECT a.id,
>     b.nome,
>     b.cod_istat,
>     a.id_impianto,
>     a.tipo,
>     a.scarico_su,
>     a.cod_ci_sup,
>     a.cod_ci_sott,
>     a.bacino_elementare,
>     a.codice_lims,
>     a.posizione_corretta,
>     a.codice_scarico,
>     a.utente_inser,
>     a.data_inser,
>     a.utente_modif,
>     a.data_modif,
>     a.cod_asta_reg
>    FROM catasto_scarichi.a_punti_scarico_sfioratori a,
>     basi_amministrative.comuni_fvg_2014_3004 b
>   WHERE st_contains(b.geom, a.geom);
> ALTER TABLE catasto_scarichi.scarichi_comuni
> GRANT ALL ON TABLE catasto_scarichi.scarichi_comuni TO
> catasto_scarichi.scarichi_comuni TO sitarpa_catasto_scarichi_editors;
> GRANT SELECT ON TABLE catasto_scarichi.scarichi_comuni TO
> GRANT SELECT ON TABLE catasto_scarichi.scarichi_comuni TO pippo;
> rises saying:
> If I open a query window and execute:
> SELECT a.id,
>     b.nome,
>     b.cod_istat,
>     a.id_impianto,
>     a.tipo,
>     a.scarico_su,
>     a.cod_ci_sup,
>     a.cod_ci_sott,
>     a.codice_lims,
>     a.codice_scarico,
>     a.utente_inser,
>     a.data_inser,
>     a.utente_modif,
>     a.data_modif,
>     a.cod_asta_reg
> No error is given and data are retrieved, both for pippo and sitarpa_admins
> member..
> Where is my mistake??
> Thanks!
> pietro
> http://postgis.17.x6.nabble.com/Query-View-permission-deny-strange-behaviour-tp5010068p5010075.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <javascript:;>
> http://lists.osgeo.org/mailman/listinfo/postgis-users
Sent from my iPhone.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160518/0a63874d/attachment.html>
