[postgis-users] POINT/MULTIPOINT EMPTY problem in dump
Jan Michálek
godzilalalala at gmail.com
Sun May 22 14:19:01 PDT 2016
I need to solve this problem
I have in table column POINT, some of values ARE 'POINT EMPTY' (dont ask me
why, it is not my table).
MULTIPOINT EMPTY and POINT EMPTY has same representation
(010400000000000000).
If i try restore table from dump, it is problem because postgis read this
as multipoint empty, but the column has type POINT.
My version of postgis
jelen=# select postgis_version();
postgis_version
2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
Postgre is 9.3.
Is there somebody who knows how to solve this problem?
Thanks Je;
jelen=# CREATE TABLE t3 (id serial primary key, geom geometry(POINT, 0));
CREATE TABLE
jelen=# insert into t3(geom) VALUES ('POINT EMPTY'::geometry);
INSERT 0 1
jelen=# SELECT geom from t3;
geom
010400000000000000
(1 row)
jelen=# SELECT ST_AsText('010400000000000000');
st_astext
MULTIPOINT EMPTY
(1 row)
jelen=# INSERT INTO t3(geom) values('010400000000000000');
ERROR: Geometry type (MultiPoint) does not match column type (Point)
jelen=# insert into t3(geom) SELECT geom FROM t3;
INSERT 0 1
jelen=#
Jelen
Starší čeledín datovýho chlíva
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160522/ce629859/attachment.html>
