[postgis-users] POINT/MULTIPOINT EMPTY problem in dump
Paul Ramsey pramsey at cleverelephant.ca
Sun May 22 18:10:46 PDT 2016
Temporarily change column type of the table you're loading from
Geometry(Point) to just plain Geometry, then you can load both types
and then change the MULTIPOINT EMPTY to POINT EMPTY then change the
type back to Geometry(Point)
P
On Sun, May 22, 2016 at 2:19 PM, Jan Michálek <godzilalalala at gmail.com> wrote:
> I need to solve this problem
> I have in table column POINT, some of values ARE 'POINT EMPTY' (dont ask me
> why, it is not my table).
> MULTIPOINT EMPTY and POINT EMPTY has same representation
> (010400000000000000).
> If i try restore table from dump, it is problem because postgis read this as
> multipoint empty, but the column has type POINT.
> My version of postgis
> jelen=# select postgis_version();
>             postgis_version
>  2.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> (1 row)
> Postgre is 9.3.
> Is there somebody who knows how to solve this problem?
> Thanks Je;
> jelen=# CREATE TABLE t3 (id serial primary key, geom geometry(POINT, 0));
> CREATE TABLE
> jelen=# insert into t3(geom) VALUES ('POINT EMPTY'::geometry);
> INSERT 0 1
> jelen=# SELECT geom from t3;
>         geom
>  010400000000000000
> (1 row)
> jelen=# SELECT ST_AsText('010400000000000000');
>     st_astext
>  MULTIPOINT EMPTY
> (1 row)
> jelen=# INSERT INTO t3(geom) values('010400000000000000');
> ERROR:  Geometry type (MultiPoint) does not match column type (Point)
> jelen=# insert into t3(geom) SELECT geom FROM t3;
> INSERT 0 1
> jelen=#
> Jelen
> Starší čeledín datovýho chlíva
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
