[postgis-users] topology - topogeo_id <> mylayer.mypk
Sandro Santilli strk at kbt.io
Tue May 31 01:31:00 PDT 2016
On Mon, May 30, 2016 at 10:33:07PM -0500, Garret W wrote:
> What I dont understand is why in some cases the relations table has been
> assigned the correct IDs from the original table and when it seems to
> provide its own.
There's absolutely no attempt to do any matching between the relation
table and the original data. They just usually happen to start with
1 and move incrementing by 1, thus you can often find a similar
pattern ...
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   https://strk.kbt.io/services.html
