[postgis-users] topology - topogeo_id <> mylayer.mypk
Garret W garretlewis at gmail.com
Tue May 31 08:42:19 PDT 2016
Ahh. I see. Then you very much for the help and clarification.
Garret
On May 31, 2016 3:31 AM, "Sandro Santilli" <strk at kbt.io> wrote:
> On Mon, May 30, 2016 at 10:33:07PM -0500, Garret W wrote:
> > What I dont understand is why in some cases the relations table has been
> > assigned the correct IDs from the original table and when it seems to
> > provide its own.
> There's absolutely no attempt to do any matching between the relation
> table and the original data. They just usually happen to start with
> 1 and move incrementing by 1, thus you can often find a similar
> pattern ...
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   https://strk.kbt.io/services.html
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160531/90c4fd7d/attachment.html>
