[postgis-users] How does one make sense out of the postgis garden tests results?
Sandro Santilli
strk at kbt.io
Mon Nov 14 05:36:59 PST 2016
On Sun, Nov 13, 2016 at 01:25:55PM -0700, sablok wrote:
> Can I also write my own test cases and integrate them with the make check
> target that postgis already has? I sure will change the path to pg_config
> and try running the make check target
Yes, you can add more tests. Just ask for help when you need it.
--strk;
