[postgis-users] How does one make sense out of the postgis garden tests results?
sablok sablok at amazon.com
Sun Nov 13 12:25:55 PST 2016
Can I also write my own test cases and integrate them with the make check
target that postgis already has? I sure will change the path to pg_config
and try running the make check target
View this message in context: http://postgis.17.x6.nabble.com/How-does-one-make-sense-out-of-the-postgis-garden-tests-results-tp5010601p5010615.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
