[postgis-users] How does one make sense out of the postgis garden tests results?
Sandro Santilli
strk at kbt.io
Sun Nov 13 06:11:19 PST 2016
On Sat, Nov 12, 2016 at 12:54:58PM -0700, sablok wrote:
> Is there a way to execute all the tests that make check and make installcheck
The tests performed by "make check" and "make installcheck" are the
same, with the only difference being "make installcheck" installing
PostGIS as an extension while "make check" installing it via script.
The reason why there's a distinction is that EXTENSIONs can only be
installed from system directories.
> executes against a non standard postgres installation.
Both EXTENSION (installcheck) and non-extension (check) tests can
execute against non-standard postgres installation. Actual
installation paths are extracted from the pg_config that's found
at ./configure time.
> go about executing the test cases that postgis run against this
> installation?
Had you tried to just run those make targets ?
It's easier to help you fight monsters if you actually meet them :)
--strk;
