[postgis-users] Restore a raster dump from PostGIS 2.1.0 to PostGIS 2.3.0
Cedric Duprez
Cedric.Duprez at ign.fr
Fri Nov 25 06:11:37 PST 2016
Still same issue with two servers having the same configuration.
Regards,
Cedric
Le 21/11/2016 à 11:16, Cedric Duprez a écrit :
That's right... On the target instance, the user is not exactly the same
as on the original instance.
This is due to a global settings backup problem I am trying to solve.
I will try again with the same users and tell you if it works.
Thanks for your help.
Regards,
Cedric
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161125/af38807e/attachment.html>
