[postgis-users] geocoding failure
Sara Yurman
syurman at spatialfocus.com
Fri Oct 14 05:46:20 PDT 2016
I have the tiger geocoder extension installed, and the tiger data loaded
for the state of Georgia. I can get a reasonable response from the
geocode_intersection function, but geocode, geocode_address and
reverse_geocode always fetch 0 rows.
For example:
select geocode_intersection( 'Patterson Ave', 'Walnut St', 'GA',
'Scottdale', '30079', 1 );
Gives this (correct) result:
"("(312,,Patterson,Ave,,,Scottdale,GA,30079,t)",
0101000020AD100000465ED6C4021155C0AB764D486BE44040,0)"
But this:
select * geocode_address( normalize_address( '312 Patterson Ave, Scottdale
GA 30079' ) );
Yields 0 rows. I just get the header (addy, geomout, header).
Similarly, I can get the coordinates for the intersection:
select st_astext( geomout ) from geocode_intersection( 'Patterson Ave',
'Walnut St', 'GA', 'Scottdale', '30079', 1
Results in:
"POINT(-84.265794 33.784524)"
But
select
pprint_addy( r.addy[1]) as st1,
pprint_addy(r.addy[2]) as st2,
pprint_addy(r.addy[3]) as st3,
array_to_string(r.street, ',') as cross_streets
from
reverse_geocode( st_geomfromtext( 'POINT(-84.265794 33.784524)',
4269),true) as r
Gives me 0 rows again.
I'm doing something very wrong. Any nudges in the correct direction much
appreciated.
Thanks in advance,
Sara
Sara Yurman, GISP
Spatial Focus, LLC
Geodata Architects
http://www.spatialfocus.com/
Office: (404) 378-0989
Fax: (404) 806-6257
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20161014/ce43755a/attachment.html>
